Results 1 to 1 of 1
November 22nd, 2010 07:50 PM #1
hello,
ride is L200 4d56T.
first, started out fine sa umaga. kumbaga gapitik sa switch
after a long traffic, temp gage registered 1/4 but the normal running temp is aligned at the C mark. so lets consider this as "beyond normal running temps"
shut down engine to buy some supplies for the family.
after the errand, starter turned lazily and it took approximately 5 seconds to start engine while still very hot.
about a month ago, i had a continuous streaming of bubbles at the rad. even with engine cold, nagbibuildup agad pressure sa rad.
ganun din kanina pagpasok sa work. i let the glow plugs glow for about ten seconds then voila! start din agad. pagdating sa workplace, cooled off engine before shutting down. after shut down, i restarted again and voila! starter turned very lazy again yet it started after approx 5 seconds.
it idles smoothly. for the acceleration, i can't feel any difference at all since daily driver ko yung pipip ko.
Question is:
1. Is it the leaky head gasket that contributes to the "engine starting lazy"?
2. Could the starter carbon brushes worn out? (note: at idle batt voltage is 14.4 so a weak battery is ruled out since batt is about 1 year old)
3. Is it the injection pump?
4. Others? i can't seem to identify other faulty engine parts.
Any comments would be welcome. pagusapan natin ng maige etong problema ko mga repapips.
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
