Results 1 to 10 of 15
- Apr 2008
- 99
March 31st, 2009 08:53 AM #1hi,
my mechanic recently replaced my distributor o-ring and i'm not sure if it was adjusted properly since he didn't use any timing light to advance/retard ignition timing. do i need to have it checked and readjusted? drivability seems the same though.
TIA
March 31st, 2009 09:16 AM #2
- Apr 2008
- 99
March 31st, 2009 09:25 AM #3
March 31st, 2009 09:34 AM #4
- Feb 2008
- 577
March 31st, 2009 06:01 PM #6
Alam niya kung saan sparkplug nakaturo ang rotor.
One spline off makes a big difference.
Its taught in tech school. Alala ko tuloy yung 4k practice engine namin.
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 10th, 2009 10:05 AM #7galing naman nya if he adjusted timing without a light. if it's by feel lang then i would have it checked by a shop that has a timing light and knows what the timing for your engine should be.
- Dec 2006
- 273
April 10th, 2009 06:50 PM #8Madaling ma-adjust ang ignition timing without the help of a timing light (if you are still using contact points).
- Jul 2003
- 573
April 11th, 2009 04:35 AM #9tonyboy,
you didn't post your car and year model to begin with. how do we know what type of distributor you are talking about then? Is it attached at the end of the camshaft and in line with the camshaft, or is it attached somewhere inclined to the engine block, where the end of the distributor shaft drives the
oil pump? This will help to know how to set the timing, if disturbed.
THE AUTO SPECIALIST
- Mar 2006
- 607
April 11th, 2009 04:51 AM #10
I have a feeling its the other way around...
