Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Pansin ko lang... dito lang sa Pinas rated ang 1ZZ-FE as 145hp... sa ibang ASEAN countries ay 134hp lang siya...
    I agree, medyo overrated yung 145 HP... probably as a marketing gimmick than anything else. Just like the TOM's Turbo Corolla, they first claimed it to be 200HP and later changed it to about 150HP.
    Jan 2003
    hmmm. yung 7K-E rin medyo overrated. dito ata 96hp tas sa indonesia mga 84 lang ata. measured at different rpms...
    and in the US, the same engine is rated at 130 hp, 125 lb-ft (although it may be because of US emissions controls)
    Jul 2003
    sir mazda ang alam ko 134HP sya or 136HP sya sa altis, pero changed ata un d ko alam ano kaya siya umabot ng 145 HP.. yun ang pagkaintindi ko, with the same engine...
    gamit siya ng celica ata before.. kaya alam ko malakas talaga yang engine na yan..tsaka bias ako haha
    dyno testing a 1.8 corolla will solve ur problem :D or any other facility which measures crank hp
    so who will volunteer 5K for dyno testing the Altis 1.8? :D
    yung nasa MR2 spyder rated at 138hp yata. Kahit sa Celica GT ganun din. yung isnag engine nga Celica na 1.8 yun yung 180 Hp.
    OT:
    other car manufacturers are guilty of this. ;)
    The 124Hp Lancer, 130Hp ES Civic. Kahit yung local SiR di daw talaga 160Hp because of the different ECU installed. pag nilagyan ng JDM ECU yung SiR saka lang mamaximize yung 160Hp
    Jul 2003
    pogi ng tank mo sir supierreman ah.. hehehe
    the celica gt-s is which also using this engine is rated at 180hp.
    the lotus elise is also using this engine. although they used their own engine management software and upped it to 190hp. although the downside to this is the high engine temperature and neccesitated the use of an oil cooler for the elise.
    i guess the other countries have catalytic converters installed. Plus, iba siguro settings ng computer box nila to compensate for the prescence of the cat.
    naka drive na ko ng altis 1.8g, malakas talaga kahit na matic, sarap i-drive
    yup, the Altis 1.8G is nice to drive.
    BTW, it's relatively easy to drift around a corner too. I did it before, during one of the Toyota Test Drive Days at The Fort. :D
    di pa ko naka drive ng altis... patest drive naman jan...
    you dont need to borrow someone else's car to test drive a corolla altis... Just wait when Toyota does a test drive weekend, usually at the FORT. All you need is a driver's license.
    i drive a 95 corolla CE with a 4A-FE, and when i drove a 2000 Corolla (1ZZ-FE engine debut in the 2000 model with 125hp) i felt a big difference in power! The 1ZZ-FE is way smoother than my 4A-FE. I Felt the 4A-FE just aged.
    Toyota just recently realeased a new corolla XRS, i can't believe they put the 2ZZ-FE GT-S engine on it with 10hp less compare to the celica's 180hp. I'm thinking of getting it next year after i get my tax return
    kelan kaya yun?
    Jan 2003
    wow! Im so excited! sige puntahan ko na friend ko! ma test drvie nga.
    Jan 2003
    how much is the altis nga pala ngayon?
    kelan kaya yun?
    usually when toyota is launching/promoting a new vehicle, they will have a test drive day or two. Just watch out for that.
Is the 1ZZ-FE (1.8L VVTi) overated?
