Results 1 to 10 of 22
June 18th, 2004 10:05 AM #1
Pansin ko lang... dito lang sa Pinas rated ang 1ZZ-FE as 145hp... sa ibang ASEAN countries ay 134hp lang siya...
June 19th, 2004 10:37 AM #2
I agree, medyo overrated yung 145 HP... probably as a marketing gimmick than anything else. Just like the TOM's Turbo Corolla, they first claimed it to be 200HP and later changed it to about 150HP.
June 19th, 2004 11:06 PM #3
hmmm. yung 7K-E rin medyo overrated. dito ata 96hp tas sa indonesia mga 84 lang ata. measured at different rpms...
June 20th, 2004 12:18 AM #4
and in the US, the same engine is rated at 130 hp, 125 lb-ft (although it may be because of US emissions controls)
June 20th, 2004 12:30 AM #5
sir mazda ang alam ko 134HP sya or 136HP sya sa altis, pero changed ata un d ko alam ano kaya siya umabot ng 145 HP.. yun ang pagkaintindi ko, with the same engine...
gamit siya ng celica ata before.. kaya alam ko malakas talaga yang engine na yan..tsaka bias ako haha
June 20th, 2004 03:22 AM #6
dyno testing a 1.8 corolla will solve ur problem :D or any other facility which measures crank hp
June 21st, 2004 01:24 PM #8
yung nasa MR2 spyder rated at 138hp yata. Kahit sa Celica GT ganun din. yung isnag engine nga Celica na 1.8 yun yung 180 Hp.
OT:
other car manufacturers are guilty of this. ;)
The 124Hp Lancer, 130Hp ES Civic. Kahit yung local SiR di daw talaga 160Hp because of the different ECU installed. pag nilagyan ng JDM ECU yung SiR saka lang mamaximize yung 160Hp
June 29th, 2004 02:07 PM #10
the celica gt-s is which also using this engine is rated at 180hp.
the lotus elise is also using this engine. although they used their own engine management software and upped it to 190hp. although the downside to this is the high engine temperature and neccesitated the use of an oil cooler for the elise.
I think they took over Sept 2023... I remember their event presented the 296 GTB and the Purosangue...
Car Sales Data (2024)
