Results 1 to 2 of 2
Threaded View
    Dear Rusty:
    Although one of the reasons that I installed the water-methanol injection system was for the cleaning effect, the cleaning was not as dramatic as I expected.
    On the DevilsOwn website you can see before-and-after pictures of a EGR (exhaust gas recirculation) valve that got cleaned by the spray of water-methanol.
    The cleaning results were pretty impressive.
    The problem is, like you, my engine is NOT a Turbo - therefore it doesn't have the dramatic increase in manifold pressure and air delivery associated with one.
    As I have said before, my system has progressive delivery matched to the engine's airflow.
    Also I have installed the smallest (D01) nozzle available.
    I cannot use a larger nozzle because:
    1) the engine simply cannot take such a high delivery without flaming out and shutting down (flooding on a diesel!).
    2) the alcohol consumption goes through the roof - the whole 2 liters disappears after 15 to 30 minutes - depending on how you drive.
    The small spray makes for a small cleaning effect - unlike with a standard system (pressure-switch controlled) that just turns FULL ON when the trigger pressure is reached - which makes for tremendous washing effect.
    Nevertheless the engine always runs better and crisper after turning on the water-methanol so some cleaning definitely does occur.
    As to the spray bottle cleaning idea, I do not believe you will be able to match your spray to the engine airflow manually, and if you put in too much water - you could damage your engine (the dreaded hydro-lock).
    Another thing that could go wrong is the mixture spray catching fire and BACKFIRING through the intake manifold - with nasty consequences.
    Sincerely,
    Dusky Lim
Water-Methanol Injection for Diesels
