Results 1 to 10 of 19
- Dec 2004
- 41
September 24th, 2006 10:31 AM #1While driving po, biglang namatay ang engine, buti na lang malapit na lang sa bahay. Then after 15 mins (I went to call my suking mechanic) nag start na. Pina adjust ko ung menor (Sa gabi, bumababa ang menor to 550 - 600 when I turn on the headlights.) then while doing this bigla na naman namatay ung makina, pero na istart naman. Ano po kaya ang problema?
Ride is XL 93 big body.
2SM battery is old = more than 2 yrs (or maybe more), 2nd hand ko nabili ung kotse and 2 yrs na sa akin. May mga salt deposits sa takip ng battery.
Iyong alternator napalitan na ng surplus 2 yrs ago.
Napacheck ko na ang charging ng battery last week only ok naman daw. Pero sabi sa akin na it is time to change my old battery.
Kaka change oil and minor tune up ko lang last week.
TIA.
September 24th, 2006 10:40 AM #2
Try cleaning your battery's terminals... baka loose contact lang yan.
September 24th, 2006 10:44 AM #3
pag naka idle ka, dumidilim ang headlights? pag nakapatay ang engine mahina ang tunog ng busina mo? pag umaandar ang engine mo at nag rev ka, madilim pa rin ang headlights or lumiliwanag pa? dahil kung ganoon ang situation its either the battery since sinabi mo na morethan 2 yrs na siya at mahina na, or pag madilim ang headlights mo kahit nag rev ka malamang alternator ang may sira...
eitherway its better to have professional mechanic take a look at it, hirap din masiraan sa daan... perwisyo, abala, init ng ulo, at karagdagan na gastos aabutin mo kapag nangyari iyun...
Toyota is my choice
- Aug 2005
- 2,063
September 24th, 2006 07:05 PM #5
Check the solenoid that's attached to your carburetor. If it breaksdown mawawalang ka ng menor.
September 24th, 2006 07:23 PM #6
bro, ganiyan din oto ko..due for replacement ang battery ko, eh..pag bukas ng headlight, lumalabo ang clock...tapos pag naka-ac/sounds ala na busina..pero pag nagrev ako, bumabalik ang busina..pasaway ano? hehehehe
the best, palit ng battery..baka itirik ka na nyan...hirap pag ndi na nag-start yan in the middle of the traffic...
ako ipon pa ng konti para sa budget to replace the battery,eh...
September 25th, 2006 11:49 AM #7
- Dec 2004
- 41
September 25th, 2006 11:54 AM #8Sir Afrasay, tnx for the reply. Medyo iba ung reply mo pero napaisip ako kasi
1.) di naman ako nagkakaproblem sa pag start ko sa umaga. One click lang, in fact di ko na inaapakan ang gas pedal bago ako magstart pero ok naman.
2.) All lights, busina, wiper, radio, aircon ok naman. Kahit nakabukas lahat, di ko nakikita na lumalabo ang mga ilaw ko.
3.) At noong nasiraan ako, naistart naman namin ung kotse (one click pa rin start na).
Pero ung battery at alternator ipapacheck ko na rin, kasi matagal na battery ko at ung alternator ko napalitan na ng surplus.
To all, tnx for the reply.
September 25th, 2006 12:58 PM #10
I think the culprit is the battery. Replace it since it's already 2 years old.
So it's basically the size of the Corolla Cross but about 200kg lighter? If the FWD version will...
2022 Suzuki Grand Vitara Smart Hybrid
