Results 1 to 9 of 9
- May 2010
- 4
May 25th, 2010 07:59 AM #1nagchecheck engine siya and minsan wala naman. Kapag nakapatay un check engine ang ganda umatak and pino umandar pero kapag nakabukas check engine wala gaanong hatak and mausok ng itim sa exhaust. Bkit ganon? do i change my servo? i cost 7 thousand pesos and if I change it would my problem be fix?
- Nov 2009
- 456
May 25th, 2010 09:57 AM #2Natune-up na ba recently ang kotse? Make sure na malinis ang air filter element at bago ang oil at oil filter. Consider cleaning the MAF (mass airflow sensor) and also the IACV (idle air control valve or servo).
- Jul 2003
- 573
May 29th, 2010 12:42 AM #3servo is used to control the engine rpm/speed at idle. looks like you are running rich mixture. better have the check engine code read out with the diagmostic tool
- Jun 2010
- 76
July 12th, 2010 02:13 PM #4sir yun tingin ko lang ay yun adjustment ng tps yun sa idl so kailalangn po touch point po yan..kasi nagpalit nga po kayun ng servo
July 12th, 2010 03:42 PM #5
Sa akin kung may usok na maiitim iyong maf sensor may problema kung may sira. tignan mo rin kung nag revved hanggang 2500 rpm lang. May problema maf.
- Dec 2010
- 3
December 23rd, 2010 10:36 PM #6Mga pare, tulong namn yung car ko nagloloko yung servo saan pa pwedeng dalhin yung car ko at nababasa yung filter ko ng lanagis tulong naman po...
- Dec 2010
- 3
December 23rd, 2010 10:42 PM #7Mga pare, baka may alam po kayong magaling gumawa ng servo motor ng car ko di kasi nagana tapos pag nag air-con ako nabagsak yung RPM nag wa wild yung makina pag di naman bukas mataas yung minor ng car ko tulong naman po. tawa San Pedro,Laguna po ako.
- May 2011
- 1
- Jul 2003
- 573
May 19th, 2011 05:24 PM #9you have two options:
1. servo repair kit
2. complete servo asm
bettro have it checked first by an auto technician and decide which repair solution is applicable. the servo is adjusted for correct idling when the AC compressor is engaged.
Suzuki JIMNY [merged threads]
