Results 1 to 17 of 17
    Jan 2014
    Kia CARENS Crdi 2.0 automatic ang oto ko.
    Newly changed timing belt at atf fluid. Change oil will be done by next month.
    may sinasabi ung mekaniko na parang related sa "throttle" dahil electrical daw ung oto at walang kable sa throttle.
    Any ideas guys? Hirap pag electrical. Thanks.
    Here is the scenario.
    At full stop, hirap umarangkada ang oto kapag full step sa pedal. No engine revs at an instant but after 3 to 5 seconds holding the gas pedal it will abruptly accelerate fast.
    Another thing is kapag nasa gear 1, rev to red then the tranny will switch to gear 2 it will lose power especially on uphills resulting to go back to gear 1. In short, redundant ang change ng gear niya pag paahon. ## gain speed sa gear 1 then will shift up to gear 2 - loose power then shift down to gear 1 again.
    Jun 2006
    Try resetting everything...bunutin mo negative side ng battery and wait for 10min before reconeccting again.
    Or
    Try mo trick to recalibrate the electronic throttle... fully press throttle on engine off, then turn on to ignition...dont crank the engine. Wait for 10sec then release the throttle then fully off the key.
    Jan 2014
    Quote Originally Posted by shibby75 View Post
    Or
    Thanks sir. Try ko ngaun. Update kita.
    Jan 2014
    Or
    No changes sir
    Jan 2014
    Please close/delete the thread mods. Thanks.
    Ano updates sir? Share mo naman dito
    May 2016
    It has something to do with the adjustment of the throttle. See a mechanic to adjust it para hindi nasasakal ito at hirap umarangkada.
    Jan 2009
    Quote Originally Posted by Mon Santos View Post
    Electronic throttle control. No manual adjustments.
    Jan 2014
    Mga walang alam sa electrical ang mga mekaniko dito sa antipolo e. Takot sila na galawin ang oto baka daw masira ung ecu.
    Noted about the electronic throttle control.
    Jul 2014
    Anong model ng car mo sir?
    Sent from my ASUS_T00I using Tsikot Forums mobile app
    nangyari problema before or after changing the timing belt? dalhin mo na yan sa may scanner para iwas hula hula.
    Sep 2004
    since he has a CRDI engine, kindly check the following.
    1. check the EGR valve, it may be already blocked and needs cleaning.
    2. check the throttle position sensor, but this will throw a check engine light. better to have the ECU scanned for DTC.
    Dec 2004
    Pwede rin kaya clogged fuel filter?
    on a side note...buti makina lang yung hindi nagagalit
    Peace!
    Quote Originally Posted by corbon44 View Post
    Peace!
    First thing I check too when an engine has such problems, together with the air intake sensor, if it needs cleaning (MAF).
    Jul 2016
    Quote Originally Posted by t2erns View Post
    Eto lang ang sensible reply here. Sayang ang pera sa hula hula.
    FYI, hyundai has a ecu script wherein it will shutdown the engine if fuel filter is clogged.
    It will now that it is clogged becuase the ecu is monitoring actual fuel rail pressure values and comparing it vs. Its expected FRP values at any given engine load and speed.
    Try mo kay Fronte sa banawe dalin.
    Feb 2009
    your car's engine does not have emotions!
    have it checked by a competent and experienced technician. avoid the "cheap mechanic". you get what you pay for
[Q] bakit Hindi nagagalit ang makina?
