Results 11 to 17 of 17
May 6th, 2016 08:16 PM #11
Try this procedure.
https://www.google.com.sa/url?sa=t&s...HglOzZuo6rrlTg
May 12th, 2016 11:55 AM #12
nangyari problema before or after changing the timing belt? dalhin mo na yan sa may scanner para iwas hula hula.
- Sep 2004
- 340
May 23rd, 2016 03:25 PM #13since he has a CRDI engine, kindly check the following.
1. check the EGR valve, it may be already blocked and needs cleaning.
2. check the throttle position sensor, but this will throw a check engine light. better to have the ECU scanned for DTC.
July 15th, 2016 01:11 PM #14
Pwede rin kaya clogged fuel filter?
on a side note...buti makina lang yung hindi nagagalit
Peace!
July 15th, 2016 03:06 PM #15
- Jul 2016
- 939
July 16th, 2016 06:48 PM #16Eto lang ang sensible reply here. Sayang ang pera sa hula hula.
FYI, hyundai has a ecu script wherein it will shutdown the engine if fuel filter is clogged.
It will now that it is clogged becuase the ecu is monitoring actual fuel rail pressure values and comparing it vs. Its expected FRP values at any given engine load and speed.
Try mo kay Fronte sa banawe dalin.
July 16th, 2016 08:29 PM #17
your car's engine does not have emotions!
have it checked by a competent and experienced technician. avoid the "cheap mechanic". you get what you pay for
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
