the dyno test was inconclusive. a gain of 0.9 hp was recorded, which is within the margin of error of the instrument. ito yung post ni speedyfix sa kotse:
"guys, ang dami ko nakuha na texts from you asking for the results starting kanina pa... kulit ninyo! hehehe!
anyway, here goes...
met ceo, vp admin and others in petron kanina around 940. we headed to autoplus for the dyno pero sarado pa. they opened at 10 then we went in and waited for francisco to arrive (sya yung gumagawa ng dyno runs and is one of the best mechanics/engine builders in the philippines). some of his credentials are building a 10 second hatchback, 2 10 second evolutions, extracting 618hp out of a 4 cylinder engine and tuning most of the AF3 engines.
when he arrived, they strapped the honda city test car onto the dyno. he made 3 passes without the additive and registered a best of 76 hp. after, they poured in the additive and the first test registered slightly lower hp at something like 74.8. the next was at 76.5 and the final run with the additive registered at 76.9 for a total gain of .9 hp. for the 25% increase to hold true, the car should have registered 95 hp after the additive. differences of +-1hp are negligible and according to them, are almost the same as the other oil additives they have tested.
after the dyno run, francisco gave a mini lecture on the difference between a compression test, static compression of the engine, and many other things. he also explained the different ways of testing and how one can differ from another. he also told us ways for the previous tests conducted by nissan to be inconclusive with regard to the compression tests.
other tests such as running without the oil and water were not conducted. in talking to ceo, they plan to bring a car to the batangas racing circuit this comming august 1 so francisco can try high speed and load testing there. if he can drive it for prolonged periods on the track without the engine seizing then it will be quite a feat. ceo brought a taxi kanina the allegedly ran for 8 months without oil(pero nung dinukot yung dipstick kanina meron konte). i wouldn't recommend that anyone do this tho...
word of warning to ceo tho... better bring a car with an inexpensive engine so if it blows di mahal magpalit.
all in all, points were proven today. ceo also plans to rethink their marketing strategy and promises that the product made to the public.
again, i have no comment on the running without oil and water yet, nor the lubrication properties of the substance. we merely tried to see if the hp claim was true and it turned out false. for those na ok lang gumastos ng money for a maximum of .9hp increase then please do contact ceo and his company to get the product.
for the rest, i hope this small test we did serves to educate you to not believe everything you hear and read, lalo na with miracle products. always question, always wonder, always be sceptical.
thanks again to ceo and the rest of his staff for being gracious despite the unfavorable results.
hope this answers all of the questions regarding the test today.
Migs - 09175347636
SpeedyFix - 7237625
412 Torres St. Corner Shaw Blvd
Right Beside Toyota"
