Results 1 to 10 of 40
January 15th, 2004 01:20 AM #1
Mga bossing, san po ako pwede magpa- engine tune up ngayon na wala na sina sir ronald and alvin. Humina kasi hatak otto ko mula nung may nakita akong tagas. Sabi ng officemate ko kailangan daw pa-adjust ng balbula at yung sa gasket daw. Sensya na wala pa rin muwang sa mga bagay na yan.
Toyota Corolla, XE ride ko. From sampaloc ako, Maceda that is(malapit lang pla).
Gusto ko yung parang si Alvin(from Caltex) gumawa ng sasakyan. Nabasa ko yung tungkol dun kay "cousin freddie"... paano ba pumunta dun.. Galing ako sa Maceda. Please lang mga bossing, kailangan ko na pagawa sa friday. Thanks po.
January 15th, 2004 02:03 AM #2
OT lang. pero mdyo related.
how would i know na kelangan na ipa tune up ang sasakyan ko?
any signs?
January 15th, 2004 04:47 PM #3
saan nga ba pwde i need to tune up the opel astra? any good shope that has experience with euro cars with computers?
January 15th, 2004 04:56 PM #4Originally posted by dieselNUBI
any signs?
- idling is bit off
- noticeably slower acceleration
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 16th, 2004 01:05 PM #5check you oil. kung marumi na or may clumping, that's a sure sign you need to change the oil. also, for gas engines, kung medyo pumapalya, go for it na kasi that probably means your plugs are worn na.
5-10T kms is the usual recommended interval between tuneups
- Apr 2003
- 526
January 19th, 2004 08:57 AM #6speedyfix,
what do you mean by pumapalya? ano mapapansin mo pag pumapalya yung engine?
January 19th, 2004 10:03 AM #7
pwede namang magpatuneup sa mga gas stations diba? yung sa akin sa shell caa lang ako nagpapatuneup, every 10k, after change oil, filters tsaka plugs.
- Nov 2003
- 3,848
January 19th, 2004 11:30 AM #8yung medyo kumakadyot na yung makina kapag pinapaandar mo. or di na swabe yung pag-accelerate nya. kinda hard to explain pero once you feel it you'll know na di maganda yung takbo ng makina and that's most probably what pumapalya means
January 20th, 2004 11:41 AM #9
Si Speedyfix may shop, diba? Baka malapit sa inyo. Nakita ko na yung shop nila kaso nahiya ako pumasok. hehehehe. Nadaanan ko after ko i-tow si mbt papuntang GM Shaw.
Cooling system is sealed so atmospheric pressure shouldn't be affecting internal pressure. But...
