Hindi ganyan ung inaalok sa akin. Parang regular na rubber lang siya na kulay black.
ah... i see. copy. thanks!
i may find the cushions useful when i upgrade my rims to a bigger diameter in the future.
^ i dont think so sir, dapat spacer/lifter lalo na kung sasayad yung gulong mo, cushions will do nothing with the ride height
so, anyone who can help me please, a much better lifter/spacer other than the one sold in banawe?
salamat!
tanong lang, may lifter kasi ako nakalagay sa likod ng oto ko. Pero nakukulangan pa rin ako. Pwede pa kaya maglagay ng lifter sa taas bale taas at baba may lifter ako? Thanks
Ask ko lang din po, ung shock lifter po ba ay ginagamit para mapataas ngkonti ang lowered na sasakyan, toyota? gaano po kaya kataas? salamat
Corrected the exaggerated rake on a gen2 RAV with a pair of custom inch thick spacers that sat between the strutmounts & towers. Opted for milled metal. They're permanent & won't deform. Rubber would compress over time & throw alignment all over the place. To do this, strutmount lugs need to be swapped w/ longer 1s.
That's correct Sir. Yung black ay spacers fitted at the end of the coil springs for height adjustments. kung ilang inch ang dinagdag mo na spacer, sya rin ang taas ng height ng lift ng car mo. While yung kulay red naman ay iniinsert yan sa coils ng spring to help or aid on dampening the load. Tulong din yan sa pag handle ng load ng car mo lalo na kung full load ka ng passengers..depende sa quality ng rubber ay tatagal din and durability.
