Results 1 to 12 of 12
    Hello everyone, I need your advise. I'm driving a '97 Honda City, the problem is with the rpm. When I start my engine, the rpm revs to about 1500, then after running for about 20-30 seconds it goes down to 800 when I'm not accelerating, which I think is pretty much normal (or is it?).
    Then after driving for about 10 mins. or so, the rpm again revs up to 1500 when on standby. But the weird thing is, when I turn the engine off then on again, the rpm will flicker up and down for about 5 seconds, and then rests at 800.
    This happens every time I take my car out. The "check engine light" is off, no warning/alarm lights is on. What could be the cause of this problem? Any help would be very much appreciated. Thanks.
    Jun 2008
    Baka kailangan ng engine tune up yang ride mo. Kumusta naman ang condition ng MAF sensor? (kung meron, sorry di ko familiar ano ang makina nitong car).
    Aug 2005
    maybe your iacv is dirty. palinis mo lang sir...
    Apr 2008
    Hi city_bug, ok na ba car mo? I think I'm getting the same issue with the corolla GLi. Anong pinaayos mo? I already got some tips to clean out the sensors. Hope you can help me out.
    Apr 2009
    Quote Originally Posted by weisshorn View Post
    AFAIK, wala pong MAF sensor ang makina na ito.
    Quote Originally Posted by skyglider View Post
    +10
    Quote Originally Posted by dongsky07 View Post
    Honda ECUs are really programmed to rev 1500 rpm from cold starts. Some Nissans on 1100 rpm. Not sure on Toyotas. But cleaning dirty MAF sensors and throttle body/iacv could be a sure thing.
    Apr 2008
    Thanks isa1023,
    Any recommended shop for the cleaning? My mechanic suggested na dalhin ko na lang daw sa evangelista so readily available ang parts just in case. How much kaya ang charge for the regular cleaning?
    Apr 2009
    Thanks isa1023,
    Not sure sa price sa shop kasi DIY lang ako dati eh:
    • Carburator spray cleaner for IACV and throttle body
    • Contact cleaner sa MAF (for Nissan, yung Honda wala eh)
    MAP sensor lang hindi ko nagagalaw dun. Pero last time nag-inquire ako sa neighborhood shop sa amin na may general services (tune-up, alignment etc) 500 sinisingil sakin. Nung nalaman kong ganun lang gagawin nila eh nag-DIY nalang ako.
    Apr 2008
    Thank you. I'll look for a shop tomorrow or Monday and I'll post any feedback.
    Apr 2010
    Pasakay mga bossing.
    Nissan Sentra ECCS, parang humihinga ang idle, goes up and down. Pag naka neutral then apak brakes, rpm goes down then engine stops. parang nasasakal everytime mag be-brake, patay makina afterwards, what Im doing is apak brake then apak gas at teh same time while in neutral para di mamatay ang engine.
    Cold or hot engine, still the same. breathing rpm.
    What could be the culprit?
    Thanks in advance!
    Quote Originally Posted by theshepherd View Post
    Thanks in advance!
    Most likely an electrical problem. Have your battery and alternator checked by a competent electrician. If they turn out to be ok, have a mechanic check the ignition coil.
    May 2004
    Thanks in advance!
    common yan sa sentra... bring it sa casa then let them scan thru CONSULT.... para hindi hula hula... previously nung may Nissan bayan pa they have this Meka EB sa casa then they will use Consult to scan you car for free... hehehe...
    Nov 2013
    Hi Theshepherd,
    yan din ang problem ko sa nissan ECCS kahit e adjust ko yun sa Idle up sa makina na connected sa aircon ganun pa din e2 trying to look computerize tune up kasi ECU and eccs (computer box) saan banda naka kabit yun ignition coil?
RPM goes up down up
