Results 1 to 10 of 18
    Jan 2010
    He needs to calibrate its TPS, kung wala sa calibrated range in WCT (wide close throttle
    Are you referring to ranging the TPS from closed throttle (0.5 v) to wide open (4.5 v)?
    Jul 2012
    iscv baka puro gunk na, sabay na din linis throttle body
    Aug 2017
    Hi guys I have a problem with my 95 corolla xl 2E engine
    palyado siya sa idle taas baba needle ng rpm panget tunog ng muffler pero pag natakbo naman smooth
    bagong palit sparkplug,fuel filter, hi ten wire still ganun pa din ano kaya cause nito?? sa carb na ba ito?
    May 2011
    Quote Originally Posted by Patrick rolla View Post
    Have you thought of the spark intensity being inadequate?
    Available voltage. 100%
    Required voltage. 60%
    Reserve voltage. 40%
    If the spark observed outside of the combustion chamber is other than bluish white the spark is too weak.
    Other possible causes:
    Worn out camshaft
    Carbon build up behind the valves
    Carbon build up inside the intake and exhaust ports.
    If memory serves me right, your engine has port fuel injection. These might be clogged or sticky.
rpm bounce cause?
