Results 1 to 10 of 16
April 9th, 2013 06:33 PM #1
600 to 700 rpm should be fine. Do not go below 500, your alternator may not have enough rpm's to charge properly, and your water pump may not rotate fast enough to ensure adequate coolant circulation.
April 9th, 2013 07:18 PM #2
- Aug 2008
- 17
April 28th, 2013 10:45 PM #3sir, normal lng ba kung ung rpm ay bumababa pag naka AC? from 1000 rpm to 600 rpm, corolla 95 MT, 12 valve, carb.
- Mar 2013
- 24
April 29th, 2013 02:24 AM #4hindi sya normal, should be the opposite dapat tataas sya to compensate sa load ng aircon. first of all masyado mataas ung idle mo without aircon. it should be below 1000.With aircon, it should be around 800 to 1000, without aircon it should be around 7 or 8 or anywhere above 500 and below 1000. Basta and concept is pag nag aircon ka dapat tataas sya and hindi sya dapat bumaba.
its either you would need to adjust aircon idle screw mo (or whatever it is called) or hindi na gumagana ung idle up mo. pero if i where you i would play around with the ilde screw first. un ung screw na may spring usually found on the right side of the carb {pag nasa harap ka ng kotse}. Ung nasa left na screw na may spring choke un.
aircon idle screw (or whatever it is called) - clockwise para tumaas ung idle. counter clockwise will do the opposite.
- Jul 2008
- 479
April 29th, 2013 08:58 AM #5pardon to the TS, pero magtatanong na din ako sa mga experts, my honda accord '00 is experiencing "wild RPM" meaning: sometimes the rpm would fall to as low as 100-150 to the point na mamamatay na engine tapos minsan naman stable sya sa 700-800. that is with or without the aircon. does this mean pumapalya na yung idle up for the aircon? i already adjusted the gas cable to increase the idle pero ganun pa din when it falls way below the normal, halos mamatay na makina. pero when you slightly step on the gas, babalik sa normal. pag takbo mo at mag minor ka ulit, ayun bagsak na naman rpm. you have to step on the gas everytime you stop para umangat sa normal.
idle up ba and problema? pero bakit pag tinapakan ng konti ang gas, aakyat sya sa normal. kelangan ba sa casa dalhin para maayos ang idling or pwede sa suki nating talyer? di ba kelangan ikabit sa computer para ma adjust ng tama?
April 29th, 2013 10:25 AM #6
i think the standard RPM if aircon is off is 900 rpms.
Pag bukas, mga 800.
April 29th, 2013 10:44 AM #7
- Jul 2003
- 573
April 30th, 2013 05:30 PM #8the gas cable is not the adjuster for idle. the cable should actually have some slack to allow the throttle butterfly to completely close.or hit the throttle stopper.
idle is adjusted and set by the servo or idle controller.
- Aug 2008
- 17
May 1st, 2013 01:35 PM #9mga sir ok na po idle ng auto ko. idle up nga yung sira. salamat sa mga nagbigay ng inputs.
- Jul 2010
- 570
May 1st, 2013 01:46 PM #10
VinFast VF 3
