check engine light koya,sa dashboard mo makikita kung nakailaw siya,diagnose mo kung may error codes,nangyari din dati sa 4age ko yan nung nilusong sa baha nabasa ung ecu,rough idling,palit capacitors ng ecu ang solusyon,that was last year pa,so far so good,baka nabasa din ecu mo,pero not sure kung san located ecu ng ford lynx
*oj88,kratos: thanks po. sensya po ngayon lang uli naka-access internet... fortunately di po nadamay yung lynx ngayong bagyo. sir, di naman po naabutan ecu ng lynx. its located near wiper motor at left side of the car. wala naman po kakaiba (cel) re dashboard lights. pero i will try to go for a check up and ask to check the ecu. thanks. would you recommend any service center, thanks uli.
[SIZE=1]jppt,
if your ignition system is distributor type, start drying from inside the distributor cap, rotor, ignition wire terminals and the spark plug end of the distrubutor preferrably with ignition drying spray, or substitute with wd40(r) and dry with a paper towel or suitable dry fabric. chances are the secondary side of the ignition incurred humidity and causing the high voltage to discharge where there is moisture instead of the spark plugs. try to check the fuel filter too for traces of water. it is recommended for cars five years or older to add fuel tank additive or denatured alcohol to disperse the water in the tank to mix with the alcohol and gasoline then the water becomses combustible with the gasoline and the alcohol. either of the two will cause engine m
[/SIZE]isfires.
jick
*jick: thanks, i am not that sure pero distributorless na ata yung lynx. i will do check/ replace the fuel filter pag nakapag check up na po. will also look into the fuel additive. thanks.
i'm also wondering kse during engaging of compressor (aircon) mas malakas nginig... anyway, will check for the auxillary fan baka may tama na din. rpm is at 800. also current spark plug ko is bosch platinum, and i've read a thread na baka okay pa din daw yung ngk na usual ng ford. will include it sa check list. thanks
