Results 1 to 16 of 16
    Mar 2012
    Ask ko lang po kung leak ba eto?
    Car is innova diesel.
    Bigla bumagsak yung fc from 10km per liter to 7.3km per liter.
    Jul 2013
    Napaka labo ng description ng problema. You have to provide more details if you want good answers.
    Feb 2009
    If you can't write about the problem pictures can help
    Mar 2012
    Di pala na upload yung picture.
    Eto upload ko ulet.
    Malangis yung area na yan.
    Crancase ventilation po yan, linisin at higpitan ang clamp para hindi mag leak. Dami po factors ng FC, best method is to check your driving habits and traffic situation in your daily route.
    Apr 2012
    crankcase blowby nga. need mo lang higpitan ung connection. better still, install an oil catch can to catch the blowby oil and to prevent your intercooler (if you have) and intake manifold of clogging in the long run. imo, wala naman koneksiyon sa FC mo kahit may leak yan. check your air intake line, you might need to replace your air filter and clean your MAF sensor if you have. check your fuel filter too baka need na rin replacement.
    Mar 2012
    Nag start po kase yung drop sa fc noong huling gawa sa toyota commonwealth. Warranty claim yun. Pero sablay ang gawa so nireklamo ko sa secretary ng may ari ng toyota commonwealth.
    Naisip ko baka sa car nag take revenge ang mekaniko gumawa.
    Jul 2013
    Quote Originally Posted by chuaerick View Post
    naku sir i think mas mabuti padouble check mo sa ibang CASA
    kasi SABLAY talga yang toyota commonwealth na yan, nagreklamo din ako dyan nuon. BEFORE maintenance onti lang mga gagawin sa kotse ko tapos pumirma na ako (i even ask kung meron pa idadagdag, wala na daw)
    Tapos nun Bayaran na ang daming dinagdag na! kaya lomobo yun bill ko!
    ang SA nun na sobrang garafal eh si: Jorge Quibo
    Mar 2012
    Thank you po.
    Kelan ang replacement ng air filter for toyota innova.
    Odo reading ko is 19tkm
    ask ko ren kung oem or yung 3rd party na filter ang mas maganda.
    Jul 2013
    Thank you po.
    I've read paper filter (OEM) is better.
    Mar 2012
    Ngyari na ren saken yan sa cltoyota commonwealth.
    Tapus eto pa kaya ako nagwala doon.
    Sabi ng S.A. air filter ng aircon ang problem ni replace lang namen. Ok na daw may hangin na lumalabas sa vent sa legs.
    Ehh nun nakita ko resibo air filter lang ang naka lagay. Then check ko yung aircon kung may hangin Na lumalabas sa papunta sa floor. Ehh wala paren. Kaya ask ko ano pinalitan. Tingin namen yung cabin air filter naku luma paren. Punta ako sa engine bay tignan ko air filter ayun bagong bago.
    Pati si sir john( chinese eto. Mukhang head ng service) nun nireklamo ko sakanya. Pagkakita nya sa bagong air filter. Walang tigil na pag mumura sa chinese habang umiiling. Lahat yan while nasa harap ko at ng S.A.
    Kaya lakas ng kutob ko sinabon sila(mga mekaniko at s.a. ng todo.) At para maka ganti may kalokohan ginawa sa car. Kase para sa aircon diverter and rear airvent umabot ng 1 month ang repair.
    Mar 2012
    Tapus eto pa yung fuel indicator nun pinasok ko is just below the half mark. Tumawag sa amin si toyota at sinabi na wala na daw diesel at umilaw na yung fuel low indicator. Nag papaalam na mag kakarga sila ng 500 pesos worth ng diesel to continue the "TEST".
    Nag taka ako panu mauubos yun?
    Ayun after ng ginawa nila napsin ko na yung mga leaks and mababang f.c.
    Jun 2006
    Try another dealer. Tell them the problem.
    New air filter (intake), should've improved your FC actually.
    Mar 2012
    Thank you po.
    Ngayon sa toyota pasig na kame mag papa maintainance.
    Actually di ko pala na check kung saken ba talaga yung air filter. Baka kinuha nila sa ibang innova na nagpapa pms.
    Oct 2014
    Good Evening Po.
    Meron din ganito ang innova G diesel ko. Nakapag papalit na din ako sa Toyota Casa pero ganun pa din may tagas!
    May advice po ba kayo ano root cause nito. Thanks.
    Oct 2014
    Good Evening Po.
Near sa air intake. Leak ba eto?
