Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Mar 2012
    Tapus eto pa yung fuel indicator nun pinasok ko is just below the half mark. Tumawag sa amin si toyota at sinabi na wala na daw diesel at umilaw na yung fuel low indicator. Nag papaalam na mag kakarga sila ng 500 pesos worth ng diesel to continue the "TEST".
    Nag taka ako panu mauubos yun?
    Ayun after ng ginawa nila napsin ko na yung mga leaks and mababang f.c.
    Jun 2006
    Try another dealer. Tell them the problem.
    New air filter (intake), should've improved your FC actually.
    Jul 2013
    Quote Originally Posted by chuaerick View Post
    Thank you po.
    Kelan ang replacement ng air filter for toyota innova.
    Odo reading ko is 19tkm
    ask ko ren kung oem or yung 3rd party na filter ang mas maganda.
    I've read paper filter (OEM) is better.
    Mar 2012
    Thank you po.
    Ngayon sa toyota pasig na kame mag papa maintainance.
    Actually di ko pala na check kung saken ba talaga yung air filter. Baka kinuha nila sa ibang innova na nagpapa pms.
    Oct 2014
    Good Evening Po.
    Meron din ganito ang innova G diesel ko. Nakapag papalit na din ako sa Toyota Casa pero ganun pa din may tagas!
    May advice po ba kayo ano root cause nito. Thanks.
    Oct 2014
    Good Evening Po.
Near sa air intake. Leak ba eto?
