Results 1 to 15 of 15
    Dec 2008
    Hello po mga bossing, ask ko lang yung mga advise nyo regarding sa engine oil change during pms. Our MPV is the Baic m20 m/t. During our 1st pms * 3k kms, they use Nissan GT premium 20w50 api SN. Then nung 2nd & 3rd pms pinalitan nila ng Sportec platinum 10w30 api SL. I've read sa api website eh yung SL rating eh para sa mga unit na 2004 and older engines kumpara sa SN na para sa mga newer engine. BTW 2016 ang model ng mpv namin.
    Ano po kaya ang dahilan nito o tinitipid lang kami ng casa dahil siguro marami silang stocks nung oil na yun? 2017 namin nakuha yung unit, pagkatapos ng warranty nito ay sa labas na kami magpa pms.
    tia sa mga magre reply.
    Mar 2018
    Check your owner's manual and see what motor oil it suggests.
    Jan 2013
    Usually ang casa naman nagpapalit ng oil brands not because it's better. Basta pasok sa minimum requirement ng kotse, yun gagamitin nila.
    Mas malaki pa ang rason dahil sa discount na binibigay ng sales agent sa casa. Or dahil magaling mag market yung oil companies.
    Sent from my ONEPLUS A3000 using Tapatalk
    Apr 2012
    TS, gumaan ba hatak ng sasakyan mo? from malapot na viscosity 50 to malabnaw na viscosity 30, i guess biglang gaan siguro hatak ng sasakyan mo. ok lang yan, malamang dahil bago pa kaya nilagyan ng mas malapot para sa break in ng mga piyesa.
    Jan 2009
    Best answer.
    The engine type for this vehicle (DM15DL) seems obscure and there aren't many information about it online. In which case, the users' manual would be the best source of info here.
    Bad advice.
    You shouldn't rely just by the seat-of-your-pants when choosing motor oils. You should start with what the engine actually requires by reading the manual. The recommended oil viscosity must be used, break-in period or not.
    Dec 2008
    I've read & re-read our manual, I did not find it there, but I will try again.
    Thanks po
    Dec 2008
    Best answer.
    Bad advice.
    Thanks po
    Dec 2008
    Gumanda nga po ang hatak since nung pinalitan. Malamang nga po tama po kayo. Pero ang concern ko lang kasi yung API rating niya, imbes na i maintain na SN eh nag downgrade pa, pinalitan ng SL.
    Thanks po
    Dec 2008
    Quote Originally Posted by remzam View Post
    Thanks po
    Apr 2012
    Bad advice.
    its TS casa that changes the oil spec not me who advised him to do so. but i agree with you, we refer to our car's manual for recommended oil viscosity.
    20w50 was a mistake. its incorrect viscosity for any vehicle nowadays.
    either the SA or Mechanic was negligent.
    Jul 2014
    2013 ang unit namin pero sa manual, API SL ang minimum requirement. Ginagamit ko kung anong oil ang available. Pero sa oil filter, hindi ako nagtitipid.
    Jan 2016
    Quote Originally Posted by louiellopez View Post
    Lin Dan is 100% right! Always follow the manual's specification...
    May 2009
    Normally from what I know high viscosity oils are used on high mileage cars because of the high clearances of pistons rings. The oil serve as the sealant for good combustion. For new cars low viscosity oils are used to enhance normal break-ins and proper seating of piston rings. Hope this not damage your rings.
    Aug 2017
    Yes, car manual is best reference. Also, Platinum oil is definitely cheaper than Nissan's. I use platinum to "wash" my grab cars' engine, using it for 2,500kms and draining it early and replace with my usual oil.
Reason why Casa change my motor oil?
