Results 1 to 19 of 19
    Mar 2005
    "Nippon Micro Filter". I bought it this morning at a local shop. It's a taller than OEM. Is it any good?
    Dec 2003
    i think we had that on our petron station b4, selling side by side with VIC, GINZA etc ok naman
    Mar 2005
    Good to hear that. It's taller than OEM or VIC so I figured that company probably didn't skimp on the quality or materials...
    Dec 2003
    pag mas mataas nag oil filter di ba apektado ang Pumping ng oil? di ba yung pump is based upon air vacuum? pag masmalaki ang vacuum mas mahina ang pumping?
    Apr 2004
    ok naman yan.. it does the job... problem is, its softer than VIC, kaya pag papalitan mo na, usually nagcrumple... kaya medyo hirap minsan tangalin...
    Dec 2013
    Quote Originally Posted by Psylocke View Post
    Actually this brand is far better than VIC, as VIC has inferior filtration capabilities, you can search in google about VIC filter reviews and you will see a lot of tests about its filtration compared to the other brands, also Nippon Micro is widely use in SG, USA, Australia and etc...
    Sep 2013
    I used that before so far okay naman pero mas better pa rin sakin ang baldwin. much cheaper pa. try it in your next change oil. ;)
    Feb 2009
    Quote Originally Posted by Mojo View Post
    the oil flow starts with the oil strainer in the oil pan, next to the positive displacement pump to the oil filter, to the main oil galleries and finally to the sliding surfaces. therefore, the oil filter does not and will not have vacuum.
    Dec 2013
    Quote Originally Posted by kimbon View Post
    Actually Nippon Micro is also O.E. filter Supplier to Toyota & Fuso in Japan domestic market, so they do not skimp on materials or quality.. The reason why Micro is more expensive than Baldwin is that they manufacture their filters in Japan while Baldwin for third world countries like Malaysia or Philippines comes from China just like what Bosch is doing which is why they outsourced their filters depending on the country's market affordability.
    Dec 2013
    Like FIAMM horns which they sell here in the Philippines, they sell the cheapest FIAMM Autotech Co.,ltd.(China FIAMM) made in China models here because most of the people can not afford the ones Made in Italy or Made in USA which is very very expensive.
    Attached Thumbnails Attached Thumbnails fiamm-made-usa.jpg   fiamm-made-italy.jpg
    Dec 2013
    Yes, Nippon Micro Filter is even better than VIC filters. As Nippon Micro is one of the O.E. supplier to FUSO Japan and Toyota Japan(Some models). The filter material they use is a very high quality Japan made one, they don't import the paper element from other countries. Also Nippon Micro is the choice of rebranding companies like Beck Arnley USA for their filters, The Nippon Micro brand is widely being sold in Australia, Russia, UK, USA(Rebranded Beck Arnley) and etc... while it is also being sold in the Philippines in the Visayas and Mindanao region as a higher quality than VIC, unlike in Luzon and Metro Manila where price is KING and price is the deciding filter for automotive shops in the Visayas and Mindanao Region they let you choose if you want a better quality one or the cheaper one at least you have a choice.
    Dec 2013
    Yes, Nippon Micro Filter is even better than VIC filters. As Nippon Micro is one of the O.E. supplier to FUSO Japan and Toyota Japan(Some models). The filter material they use is a very high quality Japan made one, they don't import the paper element from other countries. Also Nippon Micro is the choice of rebranding companies like Beck Arnley USA for their filters, The Nippon Micro brand is widely being sold in Australia, Russia, UK, USA(Rebranded Beck Arnley) and etc... while it is also being sold in the Philippines in the Visayas and Mindanao region as a higher quality than VIC, unlike in Luzon and Metro Manila where price is KING and price is the deciding FACTOR for automotive shops and consumers in the Visayas and Mindanao Region they let you choose if you want a better quality one or the cheaper one at least you have a choice.[/QUOTE]
    Mar 2017
    dito that pretty decent filters
    Dec 2013
    Photo of the build quality of nippon micro filter
    Mar 2017
    I bought it once and when I cracked it through, I found a second soft spring loaded valve that apparently has no use. Pretty odd.
    Dec 2013
    Quote Originally Posted by JulesManwood View Post
    You mean to say you just bought an oil filter then you cut it open without even using it? When and where did you buy Nippon Micro brand? As far as I know it is only available in the Visayas and Mindanao region as the distributor is in Visayas. Are you a new member here in Tsikot?
    Dec 2013
    As far as I know for my vios oil filter, I asked my uncle to buy 2pcs MICRO filter from Cebu, 1pc I've already used and 1pc for my spare. Since I was curious I cut opened my last spare and so that you can see the photos inside the MICRO filter itself. I also found that it had only one spring loaded bypass valve.
    Attached Thumbnails Attached Thumbnails img_1379.jpg   img_1380.jpg   img_1378.jpg   img_1381.jpg
    May 2017
    Quote Originally Posted by JapanABC View Post
    [/QUOTE]
    May reseller/shop kaya nito sa Manila area? How much is the price difference vs Vic?
    Dec 2013
    May reseller/shop kaya nito sa Manila area? How much is the price difference vs Vic?[/QUOTE]
    Meron lang ako nakita sa bandang Baguio na shop nagcacarry ng Micro brand, I think si Ongking A/s or sa Lucena si Lucena Micron. Sa Manila only truck parts shop ang nagcacarry ng Micro brand.
    Price difference parang iba iba meron iba parang almost close price or same price dahil masmalakas Micro sa production ng specific models pero yung pang Vios ko parang 20% masmahal sa VIC.
Ever used this japan oil filter?
