Results 1 to 10 of 23
- 154
December 19th, 2010 11:52 PM #1mga bro ano kaya mga possible reason kung bakit minsan bigla ayaw mag start ng tsikot ko? kanina nagamit pa namin, tapos nagpark (patay makina) kami for about 25 minutes. pagkatapos sinubukan ko istart ayaw na, hindi rin nag reredondo, tick sound lang yung naririnig ko. nangyayari eh tumutunog yung cd drive ko na parang may binabasa (niloload) na CD.
pinaayos ko na ito dati, ginawa nung mekaniko nilinis or tinasa ata yung starter. pagkatapos nun ok na. pero after mga 4 months (ngayon) nagkaganun ulit, kaya tulak kotse para magstart, as of now nagsstart na naman na uli siya, pero nakakaphobia kapag nagpapark ako, baka bigla na naman ayaw magstart, mahirap kasi may baby lagi kaming kasama, tsaka hirap maghanap ng magtutulak.help mga bro.
- Dec 2010
- 87
December 20th, 2010 12:20 AM #2baka may naiwan kang bukas na ilaw o radio kaya na discharge. di ako nag aadvice ng repaired na starter at alternator eh. bago na para isang sacrifice lang tutal otto mo naman ang kakabitan nyan eh. atleast may peace of mind ka.
- Dec 2010
- 87
- 154
December 20th, 2010 12:26 AM #4wala naman naiwang open na ilaw, radio, aircon. gusto ko muna sana magka idea if ano dahilan nung problem, kung sa starter, alternator, or sa battery ba. tsaka ano mas advisable na unang palitan.
may idea ka ba bro kung magkano starter and alternator ng honda civic lxi 96?
- Aug 2009
- 349
December 20th, 2010 12:58 AM #5Aside sa alternator $ starter... Paki check mo yung BATTERY mo maybe may na
sira or dapat na palitan sa kalumaan.
- 154
December 20th, 2010 12:59 AM #6
December 20th, 2010 11:41 AM #7
Brand new replacement starter is about P4,800, original is much much higher. If after starting you can still use the car at nights and can be pushed-started in the morning, chances are your alternator is okay. Check first battery terminals for corrosion and both cables ( neg & pos ) for tightness (both ends).
- Dec 2010
- 87
December 20th, 2010 01:33 PM #8tama dude, wag muna tayo mag jump sa conclusion. check mo muna battery terminals mo. baka loose connection lang yan. basic testing procedure, headlight high beam tapos apply brake. tapos start mo. dapat hindi mag iinit ang battery terminal nyan. lead kase ang terminal post ng battery eh which may characteristic na nag co coated xa na nagiging cause ng insulation kaya pag maluwag ang polo ng battery mo hindi nya kayang mag bigay ng tamang ampere sa starter. pinakamagandang panlinis ng battery terminal yung coke or soda. kahit wag mo na alisin ang terminal ng battery sa wire nya. i soak mo lang.
- Jan 2005
- 445
December 20th, 2010 01:45 PM #9Patayin mo lahat ng ilaw maliban sa park ang head light, then try to crank the engine masdan mo kung hihina ang headlight pag di humina ang head light di makarating koriente sa starter. Pag humina, starter may problema.
December 20th, 2010 02:28 PM #10
Kung hindi nagreredondo malamang starter ang problema kadalasan kasi nagreredondo pa rin kung battery may problema e. Ipacheck mo baka pudpod na carbon or maluwag yung kable ng kuryente ng starter kaya nagiging intermittent. Nangyari na din sa akin dati ito natanggal lang pala yung terminal ng starter.
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
