Results 1 to 12 of 12
    hello people! merry krismas and happy new year sa lahat! itatanong ko lang sana kung paano linisin ang simota air filter. i already purchased a simota air filter cleaner and air filter oil. but the box doesn't have any instructions on how to use/apply it on the filter. please help me! Thanks!
    here's how...based on what i did with mine.
    1. spray mo yung "degreaser", then pag medyo lose na yung mga dumi
    2. wash with water then let it dry
    3. spary mo naman yung oil
    reminder, don't overdo it....baka masipsip yung oil pag sobra dami. kaya let it dry overnight after application of the oil.
    HTH ;)
    ^^^ same above then lightly spray it w/ WD40 for the finale.. kaso di ko ginagawa yung pang degreaser.
    salamat mga sir!
    remove from auto
    dip the filter in pail with powder soap
    rinse and dry under the sun
    spray with oil (simota/k&n) or wd40
    that the way i clean my filter.
    Apr 2006
    enough na ang 1 day to dry sir?
    Aug 2007
    hehehe.. nakakuha ako ng idea.. thanks guyz sa info.
    Jun 2007
    this is from K&N (same rin siguro sa simota)
    1.tap filter to dislodge dirt then gently brush with soft bristle brush
    2. spray air filter cleaner liberally soak for 10 mins or dip/soak mo sa palangana with air filter cleaner, hindi babad, ahon agad and wait for 10 mins
    3. rinse off with running water with LOW pressure, clean side to dirty side
    4. shake off all excess water ang dry it NATURALLY
    5. after completely dry spray/squeeze oil DO NOT OVERDO it
    6. wait for 20 mins or until the media absorb the oil
    7. inspect
    HTH
    Aug 2006
    kakakabit lang ng simota air filter ko sa advie ko las november., panu mu malalaman kung madumi na sya., hehehe.. and para san un oil?
    Jun 2007
    Quote Originally Posted by nat2x View Post
    usually 1year/50,000/100,000 miles yan bago linisin depende sa dust condition, yung oil agent yan para maghelp magtrap ng dust yung filter kasi nga wet type yan, apply mo yan pagkalinis mo ng filter, di tulad ng apexi na dry walang oil at lifetime no maintenance daw
    pwede ba ung knn oil sa simota filter. and may expiration ba ang oil?
    Aug 2006
    Me i use K&N for my simota air filter ok naman ang effect pero i clean it when necessary kasi iba ang conditions dito mas marumi sa atin. Just do not use high pressure air hose it may damage the fibers and if tag hirap kayo you can use Lye pero sobrang onti at minsan lang kasi it may reduce the filtration capabilites and dilution ko ng lye is 5% lang the rest is all water
cleaning a simota air filter
