Results 1 to 7 of 7
    Mar 2007
    Sir, 3 questions lang po:
    1) Pwede bang iDIY na lang ang hth installation and no tuning needed? Kumbaga sa data cables ng pc eh..plug and play lang? Basta iconnect lang ang bawat end ng hth wires sa tamang slots nya sa spark plug at distributor.
    2) Ok lang ba na hinde OEM? Nagcanvass po kasi ako ng made in japan original nasa 750 pesos lang
    3) Ang replacement po ba ng fuel filter ay dapat OEM pa rin?
    Ride is 92 honda hatchback. TY
    Aug 2004
    1. Yes. Make sure each wire is attached the same way the stock ones were.
    2. OEM is typically the best. Aftermarket wires sometimes have poor insulation that cracks, frays or melts much quicker than the stock wires.
    3. Any decent brand will do.
    Oct 2011
    3.) Preferably OEM, ung ibang fuel filter brand nga na hindi OEM kasing presyo na ng OEM.
    experience ko sa non-OEM ht wires is that medyo mahina ang pasok ng kuryente resulting in palyado.
    Jul 2011
    sorry kung OT...
    magkano cost (parts+labor) ng fuel filter replacement sa labas ng casa para sa mga models na nasa loob ng fuel tank ung fuel pump & filter?
    Quote Originally Posted by 1D4LV View Post
    I agree here. Either OEM or NGK wires are still the best option for me.
    Quote Originally Posted by CarPainter View Post
    Yes, you can do it yourself.
    You can use non-OEM wires but cheap non-OEM wires would not last long. Their insulation tend to crack and fray earlier due to the heat of the engine. This leads to electrical "leaks" which will affect engine operation.
    Not really necessary to be OEM. You can use 3rd party QUALITY replacement fuel filters too. Given it's not expensive, going cheap on this is not worth it.
Questions about High Tension Wires and Fuel Filter
