Page 1 of 2 12 LastLast
Results 1 to 20 of 41
    Dec 2014
    Noob question guys.
    Wala ako alam sa sasakyan and this is my first time to have one.
    Nung nilabas namin sa casa yung sasakyan nag pa gas kami sa caltex silver unleaded... Advisable ba or it's must na sa caltex ulit ako mag pa gas?
    If hindi naman must, Do I need to empty the fuel first bago ako mag pa gas sa ibang gas station like petron or shell?
    Thanks!
    Nope. Di naman kelangan. Ang important lang is dapat alam ninyo kung ano ang octane rating na recommended para sa sasakyan ninyo, regardless kung saan ka magpapa-gas.
    Make and model please
    Dec 2014
    City 2014 E CVT
    May 2012
    You can gas to any of the 3, caltex, shell or petron. Pili ka na lang anong octane ratiing 91, 95 or 97 iba iba lang ang name ng gasoline per gas station.
    Medyo nagmura naman na ang gas, you can go for 95 octane rating.
    Choose and stick with 1 or 2 gas station. Pili ka din kung san yung di binabaha na gas station.
    Dec 2014
    Quote Originally Posted by hachooro View Post
    Ano yang octane level? will I just tell the gasoline boy? yan ba yung silver and gold and etc.
    Aug 2010
    Paying a Premium for High Octane Gasoline? | Consumer Information
    But just to expound on this..
    There are typically three "grades" of gasoline sa Philippines...
    93 - Shell Unleaded, Caltex Silver, Petron Unleaded
    95 - Shell V-Power Gas, Caltex Gold, Petron XCS
    97+ - Shell V-Power Nitro, Petron Blaze
    You can tell the gasoline boy the name of the gasoline brand (ex. Php2000 ng Caltex Silver!) or you can simply go for the RON number, alam din naman nila yun.
    Almost every vehicle will list the octane rating necessary to run it safely inside the owner’s manual. Some manufacturers might even place a small reminder on the gas filler cover itself stating ‘Premium Unleaded fuel only’ to make sure you don’t forget. Most petrol cars are designed to run from an 87 to 93 Octane rating. Turbo charged or super charged engines benefit greater on the higher RON ratings but are in danger of the lower octane ratings due to potential "knock" caused by pre-ignition effect of lower RON fuel. In short, you won’t see a power or fuel efficiency increase by running high octane fuel in an engine that has been tuned and designed for Low RON fuel but on the flip side, running low octane fuel in an engine built for Premium can increase the risk of engine damage and will certainly impact that unit’s overall performance. I just don't know the story behind the different quality of fuels served in the market by the manufacturers and the quality of the dealership pumps/facilities specially those that seem to have water and filth in their storage tanks.
    The octane rating is also shown beside the pump.
    Aug 2010
    #1 You don't need to stick with any gas station. While I generally like filling up at Shell due to convenience of their service stations it doesn't mean I do not occasionally gas up at Petron, SeaOil, Unioil, and Total.
    #2 For the RON ratings, the most sensible choice is to get the cheapest one unless your engine has a high compression ratio that would take advantage of better fuel. But as with #1, you can use any octane rating you'd prefer -- just make sure to load your car with the appropriate fuel. Throw diesel at a gasoline car would wreck it.
    #3 Do you need to empty the fuel tank? Well, most people recommend not to run your fuel tank down, try to gas up once the fuel light turns on. At the very least, it'll give you peace of mind. You don't want to experience the panic of not having a gas station near and a pointer that's under the "E" lettering.
    ^Halos wala nang 93 ngayon bro, since DOE mandate is 91 minimum. A more updated list would be:
    91 - Shell FuelSave, Petron Super Xtra Gasoline, Caltex Silver, Total Premier, Seaoil Extreme U, Unioil Euro IV 91
    93 - Petron Xtra Advance, Seaoil Extreme 93
    95 - Shell V-Power Nitro+, Petron XCS, Caltex Gold, Total Excellium, Unioil Euro IV 95
    97 - Shell V-Power Nitro+ Racing, Seaoil Extreme 97, Unioil Euro IV 97
    100 - Petron Blaze
    Most cars sold in the country require only a minimum of 91 RON. There are a few that require 95 or 97 RON, but these are usually higher end vehicles. I find it funny that some people think their econoboxes are so high-strung that they need high octane fuel.
    100 - Petron Blaze
    Shell Fuelsave is unleaded?
    If the benefits of higher octane fuel are NIL (?) for econoboxes (that includes majority of cars in PH like my Altis), then why are higher octane fuels being sold pa? Does that mean people are being paying a higher price for nothing? Just branding? I used to gas up premium for my GLi because I thought an older engine would run better on higher quality fuel.
    Yes, Shell FuelSave is unleaded. ALL gasoline fuels are unleaded, even those sold by generic stations. Lead has been banned for decades. We've been trying to change the notion by telling our pump attendants to refer to 91 octane fuel by their brand name (i.e. FuelSave) instead of just saying "unleaded". It's quite hard to change though.
    As to the topic of higher octane, again it's a misconception. Most people think that it's the higher RON rating that makes the fuel better for their car, when the truth is that when a car is designed to run with 91 RON, using 97 RON won't make it run any better.
    However, the more expensive variants have better additives, especially in terms of detergency, or the ability to clean up deposits in your engine. Main benefit is that it should marginally increase your engine's lifespan. Better performance and/or efficiency has been recorded in controlled tests, but the difference is very minimal in real world use, and the placebo effect of using more expensive fuel makes a bigger impact.
    Bottomline - it's more marketing than real differentiation.
    I am guilty of this. When I gas up I either say "unleaded' or "premium". Shell gas attendants know what I am talking about naman. Petron is confusing with all their variety.
    Wow. I really learn a lot from you What is the difference of the fuel targeted on mass transport vehicles? That is still 91 diba?
    BTT: I gas up at one or two stations and I normally don't mix fuels. I am more comfortable that way so in case I get a fuel related problem it's easier to identify the cause. I did have an instance when casa asked me if I gassed up at a station that's "kahina hinala". I was confident in answering NO
    There actually isn't fuel for "mass transport" vehicles, that's purely marketing. DOE requires certain thresholds to be met, so gas companies can't scrimp on their fuel just so they can save on product costs. Shell has shied away from that kind of marketing, instead focusing on branding their FuelSave 91 brand as for those who are looking for the highest efficiency at the lowest price, regardless if private or public motorist. V-Power on the other hand is branded as a performance fuel who want more "excitement" with their drive. Of course, they make the difference bigger than it really is.
    Petron has an even more complicated scheme. Super Xtra Gas 91 and Xtra Advance 93 are both their "entry-level" fuels, and the only differentiation is that SXG91 is not marketed at all, while Xtra is supposedly the penny-pincher's fuel. You would notice also that in more affluent areas, they don't sell SXG91, and only have Xtra, XCS, and Blaze. In other areas, they sell SXG91, Xtra 93, and XCS. Basta magulo sila sa entry-level variants nila.
    Fortunately, XCS is clearly differentiated and positioned as premium fuel for the everyman, while Blaze is positioned and priced so much higher that it's like their luxury fuel.
    Caltex, Total, and Seaoil follow Shell's simpler scheme - 91 for entry level, 95/97 for premium.
    Lastly, those discount lane fuels that they offer are exactly the same as the non-discount lane fuels. Pag lumabas ng depot yung lorry, wala namang differentiation yan, sometimes nga same tank pa yan ibabagsak sa station - it's just that one pump is programmed at a higher price while the other is a few pesos lower - but they're linked from the same underground tank.
    bro totoo ba na mas mabilis ang pump, mas malaki chance na marami ang hangin na makarga?
    Dec 2014
    In learning from this thread.
    Noob question guys.
    Thanks!
    Sir dhisky,
    Congrats po sa New Ride,
    About naman po sa fuel pag dating sa gasoline, kahit anong brand pa yan at pag haluin ang octane rating, no problem po yan, sa long as po na "Gasoline", wag lang "Diesel"
    [QUOTE=
    About naman po sa fuel pag dating sa gasoline, kahit anong brand pa yan at pag haluin ang octane rating, no problem po yan, sa long as po na "Gasoline", wag lang "Diesel" [/QUOTE]
    all current gasoline fuels are mix-able with each other, with no ill-effects.
    just be sure your engine's octane requirement is met.
    same with diesel fuels.
    Nov 2014
    Nope. Fill rate is set by the lever that's on the pump nozzle.
    Most people prefer the fastest fill rate so they can get on with their journey quicker. If you want it slower, all you have to say to the pump attendant is "uno lang ha". This refers to just the first click of the nozzle lever which corresponds to the slowest fill rate.
    SALAMAT, Sir!
    Laking tulong nga mga inputs mo.
    Another Q, ilang liters pa usually pag nag warning light na to empty (E) ?
    Or depende rin sa car, ours is Ertiga?
    TIA ulit
Noob Question: Same gas station?
