Results 11 to 20 of 74
August 11th, 2003 08:51 PM #12
when i tried this with our trooper na A/T, put it to L, ang bilis bumaba i have to step on the brakes. yung sa patrol dahan dahan lang bumaba.
Signature
August 11th, 2003 08:55 PM #13
Dun sa RAV4(AT), wala, i just step on the brakes if the darn thing goes too fast, when going down steep grades.
August 11th, 2003 08:58 PM #14
ganun ba lahat ng mga A/T? akala ko mas ok mag engine brake ang mga A/T.
Signature
August 11th, 2003 09:02 PM #15Originally posted by boybi
August 11th, 2003 09:28 PM #16
downside of engine braking is wearing out the clutch faster than normal.
- 3,754
August 11th, 2003 10:48 PM #17It happened to me Proper Engine braking saves my life .. when the brakes fails last june.. Kala ko katapusan ko na or kung hindi man laging gastos.. swerte pa rin ako
August 11th, 2003 11:24 PM #18Originally posted by pajerokid
Sorry guys medyo malabo nga yung last part ng post ko earlier. :D
Clarification lang. Engine braking is "Menor" right? (lifting your foot off the accelerator)
I use engine braking all the time ever since I started driving. For example, lets say i'm travelling 60kph in 4th gear and i'm approaching a redlight on an intersection, i start pressing the brake using my right foot to lessen my speed and while maintaining my right foot on the brake, then I let the engine assist my braking by letting my left foot depress the clutch pedal then shift down to third gear. I do the same procedure till I reach second. This is engine braking for me :-)
- Jan 1970
- 77
August 11th, 2003 11:30 PM #19on my ride (hilux with AT) i normally use 2 or L when going downhill and it works for me, bumabagal ang takbo ko, syempre may combination ng brakes din.
- Jul 2003
- 579
August 12th, 2003 01:03 AM #20Sa AT kasi engine braking depends on your torque converters stall speed. once your revs go below stall speed, more or less parang free wheel ka na. thats why push starting an AT needs lots of speed.
Mas maganda engine brake cuz it acts like an ABS. pero tama din na engine braking wears out the clutch faster and brake pads are cheaper and easier to replace. Explanation nga sa book, todays brake systems are very resistant to brake fade and overheating so it is perectly fine to not use engine braking. Practice of engine braking began with the older cars which had no vacuum assist. Braking was a back breaking job so people opted to used engine braking to slow down.
I have other theory on why they are now discounting these hybrid units. Being left in the dealer...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
