Results 1 to 14 of 14
    Apr 2008
    Hi guys need po your help, im a newbie in automotive.
    Pansin ko kasi ang bilis tumaas ng temp gauge ko. Kalalagay po palang ng water sa reserved tank and radiator taas nanaman sya habang umaandar ako, by the time naman I stop (idle) engine still on saka pa biglang mi lumabas na usok sa hood ko.
    need po your recommendation on what to do in this scenario
    thanks in advance.
    Quote Originally Posted by gobi View Post
    thanks in advance.
    Smoke means an overheat condition. Its your cooling system reaching the pressure treshold and started discharging excess pressure (in the form of steam) thru the radiator cap. Try turning off the airconditioning system to kill the aux fan, if overheating gets worse it means your e-fan is not working.
    Here are other possible cause of overheat:
    Busted fuse/relay of the electric fan
    Defective thermoswitch - doesnot turn on the electric fan
    Thermostat stucked or not opening on OE specified temp
    Water pump not working
    You are not using a coolant. Water in the radiator should be wetter than a regular water.
    If im in your shoes, id bring it to the mechanic to inspect and overhaul the entire cooling system before it do more complicated damage. After the overhaul, use the appropriate coolant to prevent corrosion. Corrosion is the most likely cause of water pump damage, incorrect thermoswitch reading, and stucked thermostat. - Or in other words, due to poor maintenance.
    Feb 2012
    yung lite ace ko naman nag ooverheat pag naka idle na matagal na naka on ang aircon
    Sa liteacce longitudinal ang engine so ang cooling fan mo ay yung clutch-type.
    Inspect the fan bka hindi na nag e-engage ang thermoclutch. Yung coolant, thermostat, rad cap dapat regularly chncheck din.
    Kung during operation ng AC nag ooverheat baka yung aux fan ng aircon mosa harap hindi na ganun kabilis umikot.
    Feb 2012
    isa lang ung gumagana na aux fan sir
    Apr 2008
    Thanks for all the replies mga sir. my technician already check and found na mi butas from the gasket hose and need to overhaul radiator.
    would you know the cost of the gasket hose and cost of radiator overhaul?
    thanks
    Sep 2009
    ^mura lang yan. depende din sa ride. huwag kang papa-overhaul sa tabi-tabi.
    dito ka sa DANTE'S RADIATOR SHOP sa may A. Bonfiacio Caloocan lang yan. as recommended by our tsikoteers! Shop yan at mababait ang mga tao.
    Apr 2008
    thanks for the feedback.
    right now my radiator is working fine. One thing i notice since it was repaired last Tuesday, I did not use the car but when I check radiator today the tank was empty. Thus it mean there is still a leak or just a normal evaporation due to i only use water in radiator?
    Jul 2010
    Pa check mo uli yun leak sa ibang lugar. Kailangan mainit yun engine para makita yun "basa". Malakas tumulo iyan pag tumatakbo na kotse.
    Nakakasira ng engine ang umusok na engine sa hood. Kulay itim ba yun smoke? Pa change oil ka kaagad. Mag iiba viscosity ng engine oil at sisirain yun cylinder block mo. Nangyari na sa akin iyan. Sakit sa bulsa ang change engine.
    Feb 2009
    find a shop that is equipped with a cooling system pressure tester. the system might be leak free but maybe the "mechanic" forgot to bleed the cooling system and whatever coolant had been installed settled down as it filled up all the low lying cavities.
    Feb 2015
    bka po may idea k u kc lagat ngawa at npalitan ko na kaso pang ahon ang takbo ng kotse ko tumataan temp nia
    Quote Originally Posted by tamchumacera View Post
    Bawal jejemon dito 'te.
    Feb 2015
    sensya na hirap mag type lilit kc ng keypad slamat ha
    Feb 2015
    I do not speak bisaya so i will try to expalin what i think has happened here in english.
    Your radiator probably was blocked, and most likely this was caused by the use of water. If you have a decent pressurised cooling system, you MUST use a proper coolant for 2 reasons.
    1. Coolant doesnt expand when heated (will not boil out the overflow hose through the radiator cap unless it really needs to)
    2. Coolant doesn't contain iron or other detrimental elements that will block up the radiator.
    It sounds as if the radiator technician did repair the radiator, but you need to use coolant, and the coolant needs to be bled into the system, not just poured in and start engine and off you go.
    It would have appeared to be full to the mechanic but their would have been a lot of air still in the coolant passages around the cylinder head, which are now full of water, and that air has now exited the system and the total level has therefore dropped.
    You need to find a decent mechanic with respect for the cooling system who knows how to refill the system.
    Let us know how you go!
Need help, my car overheat
