View Poll Results: What do you think should be the engine temperature when draining motor oil?
Voters
13. You may not vote on this poll
  • Warm Engine
    5 38.46%
  • Cold Engine
    3 23.08%
  • Doesn't matter
    5 38.46%
Results 21 to 30 of 32
Threaded View
    Jan 2009
    Conventional wisdom teaches us that in order for oil to flow better, you'll need to warm up the engine for 5-10 minutes, turn it off, and then wait another 5-10 minutes before draining it.
    I want to try changing the engine oil after the vehicle has been parked for several hours or overnight. Theoretically, this means that most of the oil has had a chance to collect in the oil pan. In other words, I should be able to remove as much of the old oil this way.
    Consider that we live in a tropical, oftentimes, hot climate.
    So, where do you stand in this?
Poll: Draining Engine Oil; Warm or Cold?
