View Poll Results: What do you think should be the engine temperature when draining motor oil?
Voters
13. You may not vote on this poll
  • Warm Engine
    5 38.46%
  • Cold Engine
    3 23.08%
  • Doesn't matter
    5 38.46%
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
    voted doesnt matter ^_^
    i do it usually after 30 minutes (or more) naka park, mainit naman lagi so mag drain talaga ang oil.
    tapos pag patak patak nalang; i jackup passenger side, then driver side. yosi break, youtube, or kain muna bago punasan bago kabit drain bolt; next naman yung oil filter hehehe
    Yeah, either way 1% difference in the drained oil won't make much of a difference naman dito sa atin because medyo warm climate natin. Unlike in winter countries where it is better to warm the engine oil before draining it.
    #22
    Quote Originally Posted by jakewise View Post
    When engine is cold, oil is thicker, thus, draining it when warm would be better as the motor oil is less viscous
    Di ba mas malapot pag mainit? San napunta yung 0w30?
    *jakewise, pakisagot naman si bro yapoy; curious din ako kung ano sagot dyan
    Feb 2005
    #23
    wether it be hot or cold its the same meron at meron pa din matitira, that's what oil filters are for they fllter out the gunks and what ever "residues" remain in the oil, besides kung regular ka naman mag change oil hindi yan (residues and gunks) kakapit sa paligid ng loob ng engine, imho
    Sep 2008
    #24
    From what I understand, viscosity decreases (thins) with increasing temperature and increases (or thickens) with decreased temperature irregardless of oil grade (0w-30). To better visualize viscosity, think of pouring pancake syrup from the bottle. At warmer temperatures, the syrup pours fast and easy, while at colder temperatures, it’s thicker and more difficult to get flowing
    #25
    From what I understand, viscosity decreases (thins) with increasing temperature and increases (or thickens) with decreased temperature.
    pero may winter rating, yun 1st number tulad ng nabanggit ni yapoy?
    Nov 2014
    #26
    Mainit - malabnaw (manipis)
    Malamig - malapot (makapal)
    regardless of the viscosity rating
    Sep 2008
    #27
    Yes, Multigrade oils must fulfill two viscosity specifications, their viscosity grade consists of two numbers, e.g. 10W-40: 10W refers to the low-temperature viscosity ("Winter"), 40 refers to the high-temperature viscosity ("Summer").
    Jan 2009
    #28
    Wrong.
    "40" is the oil viscosity at engine operating temp (≈100°C)
    Sep 2018
    #29
    I think the best would be if your engine temperature is warm when draining oil. DIY oil change is not an easy task as it requires enough tools and skills. You just need to know the proper procedure to avoid any mistakes. Draining your oil also requires proper disposal to avoid the mess in your area. However, it's still best to bring your car to your trusted car shop if you're still hesitant about the process to avoid any problems that would affect other parts of your vehicle and lessen its functionality. Hope this helps!
    Dec 2009
    #30
    Wrong.
    The manual states atmospheric temperature not the engine temperature20191018_173855-2.jpg
    Be careful changing oil while the engine is hot..dripping hot oil could scald you
    Apr 2014
    #31
    Quote Originally Posted by beepbeepph View Post
    Mostly laman ng discussion is yun pag drain lang ng oil. Nakalimutan na pag tanggal ng oil filter. Unlike oil drain plugs na accessible, may mga oil filters na hinde basta basta. Bukod sa naka siksik ang location, minsan mapapaso ka pa sa ibang engine parts like the exhaust manifold, then meron pa yun need ng SST(special service tool) para lang matanggal ng maayos. After maluwagan is next problem saan dadaloy un used oil na lalabas.
    Atmospheric temperature based on cold starts.
    If you look into an oil data sheet, it states specs like "KV*100°C"(engine operating temp), "KV*40°C"(cold)
    #32
    It's not in conflict with what OJ888 said. The manual specifies operating ranges according to ambient temp, but the second rating is indeed for viscosity at 100°C:
    Oil viscosity and oil grades | Lubricants
    Viscosity is notated using the common classification “XW-XX”. The number preceding the “W” (winter) rates the oil’s flow (viscosity) at zero degrees Fahrenheit (-17.8 degrees Celsius). The lower the number, the less the oil thickens in cold weather.
    Even if you look at SAE tables the second measurement is 100°C/212°F:
    SAE Multigrade Oils - Viscosities and Densities
Poll: Draining Engine Oil; Warm or Cold?
