Results 1 to 6 of 6
- Jun 2009
- 44
June 12th, 2009 08:09 PM #1pls. help yung auto ko 97 vtec ph16a engine ayaw nia humatak nsa first gear plang ako and 20 kmh plng nttkbo ko galit n galit na ung makina tpos pag nsa 2nd gear mga 30-40kmh plng super stressed na mkina galit na galit na din din ko man lng mapaabot ng 80-90 kmh on my third gear na hindi hirap ung makina,,ano po dpat ko gawin o ipacheck.
pls. help i really nid it badly..highly appriciated for advices and recommendation pati n din sa mga mechanical shop na pwedeng puntahan na fair prices po..im from valenzuela.
- Jun 2009
- 44
June 12th, 2009 09:45 PM #3Sir technismo
Thank you po sa advice ,now may idea na po ako somehow kung anu ang problema. salamat po
- Jun 2009
- 44
June 12th, 2009 10:53 PM #4BTW,
My other causes pa po b ito? thnks
reply highly appriciated.thnak you again
June 12th, 2009 11:30 PM #5
All indications point to a melted clutch. Replace and you should be fine.
Be prepared to see EVERYTHING that's wrong with the car once you do so however. Getting to the clutch requires removing a lot of things
- Apr 2008
- 537
June 13th, 2009 02:03 AM #6clutch disc yan at isa pa kapag magpapalit ka ng clutch disc papalitan mo na rin ang pressure plate mo saka malaking trabaho yan dahil FWD kasi ang makina mo at maraming tatanggalin.
try mo mag canvass dito pero im sure na fair ang price
http://www.speedyfixph.com/index.html
