Results 1 to 10 of 10
    Bosses, Chiefs,
    I'm planning to "Do It Yourself" the timing belt replacement of my Tamaraw FX's 2C diesel engine. Maybe you might have pictures or guides on how to replace it specially the timing settings. I just want to make sure that I will not miss even one "teeth" of its timing gear unaligned. Hoping for your assistance. Thank you very much for the replies and suggestions! More power!
  2. #2
    copy-paste mo ung link sa cardomain ng liteace ko sa address bar mo..
    most of the pics are there...
    Chief alwayz_yummy, medyo bopol ako sa paghahanap, di ko kasi makita pictures, bale na search ko na yung mga threads about the Liteace but to no avail. I guess my restriction din connection ko kaya di ko ma view yung Pics. Request sana chief if you can send the instruction or Pics thru my email add: jvnacubuan*yahoo.com.ph. Thanks very much for the assistance!
  4. #4
    wala na sa pc ko mga pics.. eto click mo nalang:
    http://www.cardomain.com/ride/2327061
    Thanks sir Yummy. This is what I need, Nasira din water pump ng owner ng utol ko.
    May 2009
    Some techniques I used on the crankshaft pulley nut (in the absence of an impact wrench):
    1. Using a long socket handle, rest the handle on the chassis then a short burst of the starter. Voila! Crank nut loosened!
    OR
    2. With an assistant, hold the crank pulley with a chain wrench then loosen the crank nut. But wrap a thick cloth around the pulley to protect it from the chain wrench.
    Reminders:
    1. Never rotate the crankshaft in a counterclockwise direction (depends on engine though, some may rotate in a different direction)
    2. Before removing the timing belt, align timing marks first. I used cable ties to hold the camshaft and injection pump sprockets.
    3. Order of timing belt install usually is Crank-IP-tensioner-Cam
    Plus you may need to renew your oil seals, tensioner bearing/s and water pump since you are already there.
    HTH
Toyota 2C D.I.Y. Timing Belt Replacement Query
