Results 1 to 20 of 23
    Aug 2008
    Hi Guys,
    how often do we need to replace a timing belt? and how can we know that it needs to be replaced na?
    maraming salamat po!
    ^^ manufacturers normally recommend on having it changed between the 70-80km mark. consider it as part of your preventive maintenance.
    you can usually check for the condition of the belt via visual inspection, pero normally, people who are proactive do not do this, but follow the odo reading as i've stated above.
    and yes. do not hold on and hesitate in changing this. more expensive pag naputulan ka.
    usually dapat mga 100km ... that is what the manufacture recommend ... pero dito sa philippines sa sobrang traffic this is not followed usually mga 80 - 90 km pinapalitan na ...
    if your buying a second hand car it is best to replace it ... kasi pagnaputulan yan ... overhaul na ang baksak mo
    regy
    Nov 2003
    replace it at 80. when in doubt kung napalitan na just replace it.
    cheaper in the long run.
    Aug 2008
    thanks for all the advice, btw do you know where to buy original timing belt for a corolla? and do you guys have an idea how much? thanks po ulet
    Quote Originally Posted by lhie View Post
    i don't know where to get original TBs for toyotas. but somehow its at the range of 1.8k.
    take note that you would also have to replace the tensioner bearing. and if you can afford it, try to have the water pump replaced too, para tipid sa labor.
    Dec 2007
    Quote Originally Posted by speedyfix View Post
    hehehe... guys baka malito ang thread starter liwanagin ko lang 70,000 - 80,000 kilometers ang ibig nyong sabihin right? Yun ang nakalagay sa PMS ko.
    Baka kasi magpalit sya every 80 kilometers e
    follow up question narin... how about those with timing chain such as the 1nz/2nz of toyota? kelan sya dapat pinapalitan?
timing belt question
