Results 1 to 9 of 9
    Nov 2007
    I'm having a problem with my 1996 Accord. Namamatay ang makina kapag nag break ako ng long periods at kapag bumababa sa ramp ng parking o kahit anong downward incline. Habang naka traffic ako sa pababa na kalye hindi ko ma-start uli ang car hangat hindi pa siya sa patag na kalye tumuntong ulit. Pansin ko nangyayari lang siya kapag 1/4 nalang ang gas sa tank. Pag naka full tank ako hindi siya namamatayan.
    Ano sa tingin nyo? Fuel pump or baka may problem lang sa gas tank?
    most likely ang prublema jan yung fuel sending unit inside the tank ,hindi na tama ang calibration . that part needs changing to get the reading right .
    Quote Originally Posted by Joned View Post
    The fuel pickup in the gas tank might be too high from the bottom.
    Was the fuel pump replaced or serviced before?
    Nov 2007
    Not since I bought it from the previous owner 4 years ago.
    So do you think it isn't the fuel pump? I thought so too since it only happens when the car is on 1/4 gas level and going down an incline or braking. Going down the sm megamall parking causes the engine to turn off everytime once the gas is at that level.
    So it's probably something attached to the pump that is getting fuel from the tank.
    I'll have a mechanic check the parts you guys mentioned above.
    Jan 2009
    I can think of two more possibilities on top of the points raised above:
    1. Water or impurities in the tank
    2. Electrical problem
    I had experienced #1 on my Sentra before. The stalling always happens when the car is on a downward incline for several seconds. And it stalls, regardless of the fuel quantity in the tank. Finally solved it by draining the fuel tank. Took us about a week to figure it out. Though without the proper tools, we couldn't determine if the impurities were water or something else.
    For #2, it's possible that power to the fuel pump or ignition gets interrupted when the car is in a certain position.
    A lot of people know that its best way to have a lot of gasoline in your tank . Low amount of fuel inside the tank build up rust causing fuel clogged in fuel line .
    Jan 2009
    Quote Originally Posted by speed unlimited View Post
    This is applicable only on cars with steel and to some extent, aluminum fuel tanks. Newer cars uses plastic materials (HDPE) that are not susceptible to corrosion.
Patay engine pag naka downward slope and kotse.
