Results 1 to 4 of 4
    Feb 2005
    mga pips ...ano ba reason pag arangkada ko ay may tumutupe or parang nabibila ukan ang REVO GL na gas..at ano solusyon gagawin ko ..naka ilang balaik na din sa casa di nila maalis..
    .thanks in advance
    these are general things you need to check, not necessarily for the revo but for all gas engines suffering from loss of power:
    incorrectly set ignition timing
    faulty high tension wires
    fouled spark plugs
    faulty ground wires/corroded ground wire connections
    loose connection in the ignition system, especially on the ignition coil and ic
    plugged fuel filter
    plugged fuel strainer in the gas tank
    faulty fuel pump
    water in fuel
    plugged carburator jets for carb engines/plugged fuel injectors for efi engines
    faulty ecu for efi engines (nakow patay kang bata ka!)
    clogged air filters
    fully open egr valve resulting to too lean air/fuel ratio (see below)
    too lean a/f ratio (symptom = higher engine temp than usual, engine knock)
    too rich a/f ratio (cold engine, smoke)
    timing gears/chains/belts out of sync/incorrectly installed
    misaligned clutch pressure plate
    torn engine and transmission mounts resulting to too high torque on engine
    dami pa. kaya hirap sila makita sira nyan kasi dami pwede causes eh.
    Aug 2004
    well said sir yebo.
    Feb 2005
    sir yebo ..tenks galing mo talaga ...lagi ko nga read mga advice mo
parang nadadapa pag aarangkada.Mostly Gas engines
