Results 1 to 6 of 6
    Jun 2009
    pls. help yung auto ko 97 vtec ph16a engine ayaw nia humatak nsa first gear plang ako and 20 kmh plng nttkbo ko galit n galit na ung makina tpos pag nsa 2nd gear mga 30-40kmh plng super stressed na mkina galit na galit na din din ko man lng mapaabot ng 80-90 kmh on my third gear na hindi hirap ung makina,,ano po dpat ko gawin o ipacheck.
    pls. help i really nid it badly..highly appriciated for advices and recommendation pati n din sa mga mechanical shop na pwedeng puntahan na fair prices po..im from valenzuela.
    Oct 2008
    sir baka slidding na po yung clutch niyan
    Jun 2009
    Sir technismo
    Thank you po sa advice ,now may idea na po ako somehow kung anu ang problema. salamat po
    Jun 2009
    BTW,
    My other causes pa po b ito? thnks
    reply highly appriciated.thnak you again
    Dec 2007
    All indications point to a melted clutch. Replace and you should be fine.
    Be prepared to see EVERYTHING that's wrong with the car once you do so however. Getting to the clutch requires removing a lot of things
    Apr 2008
    clutch disc yan at isa pa kapag magpapalit ka ng clutch disc papalitan mo na rin ang pressure plate mo saka malaking trabaho yan dahil FWD kasi ang makina mo at maraming tatanggalin.
    try mo mag canvass dito pero im sure na fair ang price
    http://www.speedyfixph.com/index.html
pls. help me honda vtec 97
