Results 1 to 10 of 12
- Aug 2010
- 38
May 15th, 2013 06:45 PM #1i just replaced my clutch assembly (disk/plate/release bearing) and done regular change oil last weekend but eventually i got engine check error P0113 and P0135 which indicates air temperature sensor voltage is too high and error on heater sensor. I tried to reset the engine check error by removing the terminals of the battery then drained it for 20minutes. But I still get engine check error indicator. My engine become and warmer than the usual. help pls!
Thanks and cheers!
villhen
- Aug 2010
- 38
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 16th, 2013 07:38 AM #5
May 16th, 2013 07:43 AM #6
baka nagooverheat ka. i dont think its the sensors.
have it checked and scanned.
May 16th, 2013 08:08 AM #7
recheck and confirm the connections both on the HO2S and the IAT. there is a big chance the "mechanic" failed to reconnect them.
- Aug 2010
- 38
May 16th, 2013 12:03 PM #8familiar ka ba sir kung san yung mismo nakapwesto yung sensor na to?
Eto yung lumabas sakin:
P0113 - Intake Air Temperature Circuit High Input
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
Thanks!
May 16th, 2013 01:17 PM #9
- Aug 2010
- 38
May 16th, 2013 06:27 PM #10P0113 error has been resolved. I did some cleaning on sensor located near intake and MAP sensor located after throttle unit. I used throttle cleaner and contact point cleaner. After OBD2 reading, P0113 disappear.
Next thing will do now is to check HO2S wiring...
VinFast VF 3
