Results 1 to 12 of 12
    Aug 2010
    i just replaced my clutch assembly (disk/plate/release bearing) and done regular change oil last weekend but eventually i got engine check error P0113 and P0135 which indicates air temperature sensor voltage is too high and error on heater sensor. I tried to reset the engine check error by removing the terminals of the battery then drained it for 20minutes. But I still get engine check error indicator. My engine become and warmer than the usual. help pls!
    Thanks and cheers!
    villhen
    Jan 2011
    more info sir, car model, year mod, EFI or Carb type?
    Aug 2010
    honda city idsi 2004 manual
    Jun 2006
    most likely fix is change sensors
    Jan 2011
    Quote Originally Posted by userfriendly View Post
    but what if the sensors are working properly? they are there for obvious reasons. take it to a reputable shop. something is really wrong with your car.
    baka nagooverheat ka. i dont think its the sensors.
    have it checked and scanned.
Engine Check Error - Extreme Hot Engine
