if the bore is STD, the piston should be STD and so are the rings. if you O/S your rings, your engine will "stucked" up again. hehehehe. the piston ring ends are designed to have a gap provision for heat expansion, if you oversize your rings, you can not even fit the piston with the oversized rings even when the piston and the rings at 32 degrees fahrenheit
