Results 11 to 19 of 19
- 54,299
- Jan 2007
- 2,636
June 22nd, 2025 01:13 PM #12Cooling system is sealed so atmospheric pressure shouldn't be affecting internal pressure.
But the ambient air itself will be less dense and will have a reduced cooling effect.
F1 at high altitude tracks more cars overheat (just like Baguio).
June 22nd, 2025 04:02 PM #14
Not fully sealed.
The coolant pressure cap keeps the pressure inside the system at a set pressure above atmospheric pressure. So if you lower the atmospheric pressure, the valve will release the excess until it equalizes again to the set cap pressure above atmospheric pressure. Hence, the cooling system will run at a lower pressure at high elevations.
As a side note, you will see in many equipment like electronics (ie. servers, IT equipment, some consumer electronics, etc.) wherein the specs may have a stipulation about the maximum altitude the said equipment can be safely operated. It's because of the less dense air at altitude, which can interfere with the equipments' own cooling capabilities.
Case in point, most projectors has an on-screen setting wherein you can set it to Normal or High-altitude mode. The main difference is, in Normal mode, the fans operate at various speeds and would likely spin at low speed to reduce noise. But once the projector gets hot enough, the fans ramp up to high speed. But in High-altitude mode, the fans are always at high speed to compensate for the thinner air.
- Jan 2007
- 2,636
June 24th, 2025 11:11 AM #15Yeah you're right about the radiator cap being relative to ambient, but IIRC the boiling point elevation you get from a 1 bar radiator cap plus a 50-50 coolant mix is high enough that the change in elevation shouldn't matter.
Metro manila is currently 1006hPa, Baguio at 853hPa. Boiling point will be just under 100C here, 96C in Baguio -- 4% decrease.
A 1 bar radiator cap raises boiling point to 268F (130C). Applying the same 4% loss (since the percentage pressure delta will be similar) = 124.8C. I don't think a car will be seeing 120+ coolant temps even in Baguio.
AFAIK one of the reasons behind pressurized cooling systems is so that modern cars can perform at altitude -- yes the boiling point is lower, but the cooling system is overdesigned and should handle it (provided of course that it's properly maintained).
June 24th, 2025 11:43 AM #16
I think THAT may very well be one of the likely reasons.
It's quite evident that the cooling system is one of those things that are frequently misunderstood or otherwise taken for granted. Especially so if you live primarily in the lowlands like Metro Manila. With the thicker air, the cooling system is quite tolerant up to a certain extent.
But going up to Baguio, it may seem that the combination of the high elevation, sustained uphill climbs, slow-moving traffic, and frequent stop and go, contributes to a hotter than usual engine. Also, many A/Ts/CVTs have a shared cooling/heat exchanger integrated into the radiator. The conditions above would undoubtedly increase the ATF/CVTF temperature which is then dissipated into the radiator as additional thermal energy that needs to be shed.
These conditions combined together makes for an unforgiving cooling system. As such, the coolant type, coolant ratio, coolant level, pressure regulation mechanisms, overall system design, engine health, etc., becomes critical.
June 24th, 2025 12:23 PM #17
Balikan ko itong first post...
Yung mga kilala ko na naka 300cc Vespa na used for their regular commute decided to put an additional aux fan to blow the hot air out. The extra fan is not as strong as the original ones, pero its only used to complement the stock fans.
Nung may taxi pa kami (90's). Every summer, we diverted the windshield washer to spray water to the radiator.
- Nov 2019
- 1,444
June 24th, 2025 02:22 PM #18Yung extra AUX Fan is useful sa mga naka montero.
Mag improve daw yung AC system since may extra compartment daw na lalagyan ng AUX Fan for AC.
Not sure if this also helps mitigates the overheating or helps compliments the cooling system of the engine.
Since may independent AUX fan na for AC if pa installan nyo.
Hindi lang nilagyan ng Mitsubishi para maka tipid.
Is this true Montero owners?
June 25th, 2025 12:30 PM #19
I received this email from Fleetguard
Understanding coolant and recommendations
I think this webinar is not exactly for cars, but I guess, (liquid) cooling systems are similar naman for most types of engines.
Understanding Coolant and recommendations - Album on Imgur
Webinar Registration - Zoom
VinFast VF 3
