Results 1 to 11 of 11
    Jun 2014
    Hello tsikoters! Im currently facing rpm problem. Let me share you what happened.
    Yesterday I went to an electrician to have my front blower fix. He found busted fuse and wirings and have it fixed. Prior to this, my rpm is running stable at 1k. Now na ok na siya, my rpm suddenly dropped to 500-600 and as u all know, low rpm means bad running condition...
    Im no expert kaya I dnt know what to check.. Im thinking i may be facing a problem in alternator as it cant supply enough electricity to our mitsubishi grandis..
    Let me know your thoughts! Thank you!!!
    Aug 2014
    Might be the cable or the alternator, or maybe the mechanic adjusted the throttle cable screw or throttle body screw.
    Jan 2014
    adjust the RPM if you know how
    or bring it to the nearest dealer
    since the grandis is rare in the Philippines
    btw nagvivibrate ba o namamatay engine?
    Jun 2014
    Definitely not throttle i know kc where it is located and he didnt touch it. Plus last mechanic ive talked to matic daw throttle ko kusa ngaadjust.
    Nmmtayan boss. Dhil di kaya ng 500rpm lng
    Oct 2014
    Quote Originally Posted by Zac_espaņol View Post
    Na check ba ng electrician ang cause bakit pumutok yung fuse? Blown fuse shows that there is a current leak within the circuit. Kung hindi niya na ayos yung circuit, nan doon pa rin yung leak kaya bumababa ang supply mo and eventually puputok uli yung fuse.
    nag tanggal siguro kayo ng battery kaya nag bago idling. throttle motor must be re-learned after a battery reset.
    Oct 2009
    Quote Originally Posted by t2erns View Post
    +1 ako.
    subukan mo ding palitan ng bagong air filter.spark plug.fuel filter.at kailan huling na change oil yan..
    At idle ba yung 500-600rpm?
    Parang okay lang naman yan ah. Sa Lynx ko, cold start 1k+ rpm then after few minutes magiging almost 600 rpm na lang sya. Wala naman problema, hindi naman namamatay yung makina.
    Ano ba kasi car mo? Ang hirap naman manghula kung ganyan
    Quote Originally Posted by erick_214 View Post
    grandis daw (pls see first post)
    Ah mitsubishi, baka un servo nyan un may prob...
How to improve RPM
