Results 1 to 9 of 9
April 10th, 2012 11:56 AM #1
Guys help naman, ok naman radiator ko walang leak and newly overhauled. Problem is ang bilis tumaas ng temperature ko as in umaakyat talaga even if short drive lang., like when im going to banawe to QC circle. nangangamoy sunog na goma every time nag overheat. what could be the problem?
- Apr 2011
- 66
April 10th, 2012 02:09 PM #2umaabot ba sa red zone yung gauge mo? Tumotope ba makina mo? Humihina ba hatak pag sinasabi mong overheat na? Nagbabawas ba ng coolant? Check mo thermostat, baka stuck closed. Pag ok, check mo oil mo kung may milky substance - baka blown cylinder head gasket ka. Yung amoy sunog na goma, baka naman may mga debris lang na dumidikit sa engine parts mo. Check mo maigi.
April 13th, 2012 01:33 PM #4
ok naman fan ko gumagana, tumataas talaga temperature eh. di ko alam if dahil sa aircon or hinde haayz problema talaga.
- Jul 2010
- 165
April 13th, 2012 02:18 PM #5
April 21st, 2012 03:44 AM #6
Yung fan ng condenser mo gumagana ba din? Could be one reason, nangyari na sken yan. And remove mo na thermostat mo. Pampabukas lng nmn ng daanan ng tubig yan at a certain temp. Di ba mas maganda na pag andar ng makina mo may magcicirculate na na tubig? Pag dumumi na kse yan ganyan, stuck up. Walang tubig so overheat ka.
- Dec 2013
- 521
December 20th, 2013 01:18 PM #7
- Oct 2011
- 28
December 26th, 2013 09:34 AM #9
Are you losing coolant? Are your auxiliary fans working to spec? Start there first then go into checking the thermostat, water pump and radiator.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
