Results 1 to 6 of 6
- Aug 2010
- 2
August 30th, 2010 08:12 PM #1Mga masters need lang po ng advice. Meron po ako Honda civic 98 lagi po overheat at lagi ubos ang langis. pina check ko po sa mekaniko yung langis daw napupunta sa radiator. ano po kaya ang posible na palitan na pyesa? malaki kaya magastos ko dito? Sa tingin nyo po ba worth pa na ipagawa ko to o ibenta ko na lang ng mura ang kotse ko?
Sana po mapansin nyo ang problema ko.
Maraming salamat sa lahat.
- Apr 2010
- 65
August 31st, 2010 03:37 PM #2Opinion ko lang po, maaaring headgasket failure po and need ng top overhaul, worst-case scenario.
- Aug 2010
- 2
September 1st, 2010 07:42 PM #3overheat lang ako pag tumatakbo ng more than 100kmh then pag 80kmh di nman. lagi rin nauubos ang oil kaya nakaka worry. headgasket lng kaya to?
- Apr 2009
- 1,902
September 1st, 2010 07:57 PM #4Replace cylinder head gasket and overhaul radiator, replace coolant etc.
Malamang may history na ng overheat yan.
September 1st, 2010 08:07 PM #5
Kung sakali magpalit ka ng head gasket iyong original na kunin mo para sa Honda para iwas gastos ulit para sa labor.
September 5th, 2010 09:21 PM #6
try to use engine oil stop leak additives !
or stop driving & go for overhaul ASAP!
