Results 1 to 9 of 9
November 23rd, 2008 05:30 PM #1
Hello mga car guru's,
Question lang po..since i bought the car (95 ESI D15b engine Manual), i notice that everytime i use the car from cold start then pass the 60kph then slow down until bumaba siya sa 60kph, iilaw yung check engine..pero walang nagbabago sa takbo, idle as in wala..pero pag hinde konaman pinalampas sa 60kph from cold start hinde naman siya iilaw..
example:
from house (Cold start) ginamit ko siya tapos pass 60kph, iilaw yung check engine light niya..pag pinatay ko naman yung engine then turn it on again, wala na siya kahit lumampas na ako 60kph..as in wala na..
untill mga 5 to 6 hours na rest yung engine then uulit nanaman yung cold start sympthoms niya..
i tried having honda shaw casa checked it, sabi nila unknown error code daw and they want the car to stay with them for 1 week to observe...e since wala akong ibang sasakyan..sabi ko pag tyatyaga ko nalang..
i tried going to evangelista to have it check and what they did is replaced the speedsensor (without removing the negative wire sa battery) then pag gamit ko siya for 1 week, ok na..kala ko ok na ok na..pero this time bumalik siya and same sympthoms niya also nadagdagan yung problem, yung odometer bayun sa baba ng true milege ng oto, hinde na siya gumagalaw (dati gumagalaw) then yung true milege reading niya medyo hinde tama yung count..(Pano ko nasabi) - everyday gamit ko yung car and 1 way to makati from sta.mesa is 12km, so kung balikan 24km or 25km time 4 days = 100km dapat..pero napansin ko 57km palang siya..
hinde kona alam gagawin ko..
baka may advise kayo jan na nakaka experience ng gamito..pa share naman po..
Thank you for reading sa napakahaba kong problema sa oto..hehe
more power TSIKOT!!!
THE AUTO SPECIALIST
- Mar 2006
- 607
November 24th, 2008 12:25 AM #2sa passenger kick panel may green connector , kailangan mo jump wire para ma retrieve yung codes
connect the jump wire and turn the ign ON , CEL WILL FLASH THE CODES
November 24th, 2008 08:25 PM #4
hello mga peeps..update kolang po..
i tried jump the green connector socket and i get a fast 1 blink and after 4 secs another fast 1 blink light..paulit ulit lang siya after 4 secs. interval..
base sa error code nakita ko ay error code 1 which is Primary 02 sensor ang sira..
ano kaya pwede kong gawin? pwede paba palinis yung sensor or bili na ako ng sensor?
i tried asking evangelista about it..1k bigay nila surplus siya..
magkano kaya brandnew nito?
Thanks for the replies and for reading my problems..
thanks
November 24th, 2008 08:30 PM #5
ano mangyayari kung hinde ko muna papalitan yun? may masisira bang iba?
THE AUTO SPECIALIST
- Mar 2006
- 607
November 24th, 2008 11:14 PM #6
November 24th, 2008 11:37 PM #7
THE AUTO SPECIALIST
- Mar 2006
- 607
Tsikot Member Rank 5
- Nov 2003
- 3,848
I received this email from Fleetguard Understanding coolant and recommendations I think this...
