Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Feb 2004
    Bad news for me. My 94 Corolla GLi needs an overhaul. Read the previous threads. The tell tale signs are there. Some smoke when I remove the valve cover cap and the oil dip stick. Some wet oil deposit on the tailpipe. A little bit more noisier than usual.
    So I got an estimate from a shop the sells the parts and has a machine shop and inhouse mechanic along Proj 6 QC. I asked for their best price for parts and machine shop services, for the benefit of fellow tsikoteers na din.
    PARTS
    Overhaul Kit - 1650 Federal
    Master Bearing -750 Taiho brand
    C Rod Bearing - 450 Taiho
    Valves - 1900 Fuji
    Piston Ring - 950 NPR
    Thrust washer - 280
    Motor Oil - 480
    Oil filter - 190
    Spark Plugs - 600
    Timing belt - 1680 toyota
    Paint thinner - 200
    Rags - 60
    Silicon x 2 - 190
    If engine is really bad:
    Liner - 1700
    Piston - 1800
    TOTAL: 12610
    MACHINING 16 Valve 4aFE
    Resleeve - 1800
    Rebore - 2800
    Polish - 800
    Fitting - 900
    Regrind - 1800
    Oil Seal Build up x 2 - 1200
    Valve Seat and retappet - 4500
    Washing - 400
    TOTAL: 14200
    Whew! Magastos pala. Di ko pa pinapagawa.
    Do you think the quote is fair enough? Which of the Machining services are essential and which are optional? How do I know if I need to have them done on the engine?
    Gurus, pa-advise at paexplain naman! HELP!
    Oct 2008
    ganun talaga sir... sa mga gasket po nya mas maganda kung original parts po ilalagay... pero ok na din po yan
    What are the causes ba para ma overhaul ang auto? Age lang? Yung 96 GLi ko almost 50k ang quote for full overhaul pero sa top of the line na pagawaan yun (specializing in Toyota). Mahusay kausap yung may ari. Buti na lang false alarm at hindi pa kailangan ng overhaul. wheeeew.
    wala ako nakita LABOR charge
    magkano labor?
    Oct 2008
    mam.. loss of compression, blowby and engine knock..
    OT but what would cause that? Normal wear and tear? Basta ba change oil religiously hindi yan mangyayari o hindi maiiwasan basta luma na car?
    Parang ang hassle mag overhaul, option ba magpalit na lang ng engine?
    hi! Puwede ring option ang magpalit ng engine. Halos ganun dis ang gastos. That is according to my mechanic.
    Oct 2008
    yah tama mas ok pa nga yun magpalit ng engine... hindi talaga maiiwasan yun darating din yung time nya mag overhaul.. wear n tear tlga ang engine .. hehe
    Nov 2003
    that's pretty cheap na. if you trust that they can do the work well then ok na yan.
    Feb 2004
    Thanks for all your inputs! I think the shop owner is trustworthy. He guarantees the work for 6 months, and labor is 4K.
    For the machining, how do I know if my engine needs them? Para saan ba to?
    Resleeve - 1800
    Rebore - 2800
    Polish - 800
    Fitting - 900
    Regrind - 1800
    Washing - 400
Overhauling  Estimates - price check!
