Results 1 to 10 of 26
- Apr 2014
- 231
January 27th, 2018 11:12 PM #1If your car's owner's manual say the recommended viscosity is
10w30 or 10w40 ..
What happens if you use 5w30 or 5w40 ??
Is 5w30 too thin for a 20 yr old car ?? Corolla GLi 4afe ..
Currently using Mobil 10w40 ... Last year was using vTec LEV 10w30 ..
January 27th, 2018 11:36 PM #2
Motor Oil 1 1 - Chapter One - Operating Temperatures and Viscosity - Bob is the Oil Guy
January 28th, 2018 03:07 PM #4
and even with a 0w40
- Apr 2014
- 231
January 28th, 2018 06:33 PM #5
- Jun 2015
- 2,751
January 28th, 2018 09:03 PM #6
January 28th, 2018 10:24 PM #7
Personally... and it's just my opinion... a 20 y/o vehicle will probably be better off with a 5W-xx or 10W-xx. Reason being, the engine might actually benefit from a relatively thicker oil at cold start because part tolerances have presumably loosened up enough that an 0W oil may no longer provide enough initial protection.
Note also that motor oil takes a lot more time to warm up and reach the target viscosity. By comparison, the coolant temperature warms up significantly faster thanks to the thermostat valve, which can reach operating temp in about 5 minutes. Motor oil, however, could take anywhere around 15-20 minutes to reach normal operating temp. In other words, the oil might stay in the lower end of the viscosity range far longer than necessary.
Anyway, I'm just splitting hairs.Last edited by oj88; January 28th, 2018 at 10:29 PM.
January 28th, 2018 10:29 PM #8
January 28th, 2018 10:34 PM #9
hardly any difference at 40C for 5w30 and 0w40, 72.8 and 75 cSt respectively
Mobil 1 New Life™ 0W-40
Mobil 1™ ESP Formula 5W-30
- Apr 2014
- 231
January 28th, 2018 10:45 PM #10Don't have the manual when I bought it 2nd hand .. But I googled the 4afe engines used in Corollas abroad and it stated that the recommended viscosity is 10w30 or 10w40 ...
But those viscosities are from other countries, I don't know if its applicable here in the philippines tropical climate ...
Unlike your Honda, it is really widely known that 10w30 is the recommended oil viscosity ...
Boy, am I glad I never bought an Ecosport!
BYD Philippines
