mga sir tanong po kasi recently biglang it takes a minute for my car bago mawala yung CEL or check engine light. di ko kasi ma i-start oto habang naka ilaw ito.... dati naman halos 5 sec lang then nawawala na, what could be the prob???
honda esi
honda esi
Teka.. it's normal for the check engine indicator to illuminate when you turn the ignition to the ON position, you can start it anytime then. You don't have to wait for it to turn itself off ( if it ever does ), before starting. The MIL should disappear once the engine is running but if it stays on, something is wrong somewhere or if it doesn't illuminate at all on the KOEO position.
