Results 1 to 6 of 6
    Guys!
    Parang palaging may pawis yung engine ko. Pinapalitan ko na yung mga oil seal na nasa upper part ng cylinder head. (Pasensya na at di ko maalala name.) Kung nasaan yung camshafts.
    I suspect the seep is coming from the gap between the cylinder head and block. Is this even a possibility?
    I use the word seep kasi daw kapag leak eh malakas na daw yun.
    Thanks for the inputs....
    Quote Originally Posted by GBStJames View Post
    Guys!
    Hindi kaya yan pawis sa oil cooler mo?
    Nag-ooverheat ba engine ng car mo or hindi naman? May oil ba na sumasama sa oil ng rdaitor water? If hindi, wala yan sa gap between cylinder head at engine block AFAIK eh.
    Sori bro, saan yung oil cooler?
    Hindi pa naman humahalo yung oil sa water sa radiator.
    Ano ba ride mo bro? You can search the net for the oil cooler of your ride. Usually sa left side ng engine yan kasi.
    Hindi sa gap ng cylinder head at engine block yung water seepage kasi hindi ka pa naman overheat. Pero i-pacheck mo na sa mekaniko yan. Puwede din maghalo langis at tubig dyan sa oil clooler mo eh.
    Crv ride ko bro. Search ko sa net mamaya yung sa oil cooler.
    Pero malabo yata pagkakasabi ko.
    Pawis ng oil yung ibig kong sabihin sa original post ko. Sensya na.
    sa portion ba ng valve cover seal o head gasket?
oil seep between cylinder head and block
