- Wrong oil grade
- Faulty lubrication system, check strainer and suction pipe for cracks, weak oil pump, etc.
- Worn main and/or connecting rod bearings, worn out crankshaft journals
Take an oil sample from the crankcase and check for metal particles. Worn crankshaft bearings will cause an oil pressure drop. You can temporarily install a mechanical oil pressure gauge to see your true pressure.
