Greetings po to all fellow tsikoteers! I have a problem regarding sa oil leak sa engine ko. I observe this oil leak for two days na rin. Me tumatagas na kulay light-red malapit sa main-drive & it smells like ATF fluid. I get a sample of ATF fluid sa kotse then i compare it sa tagas na oil. Almost the same color, oder & texture nila kaya I conclude na ATF yun leak. I bring it to my friendly car repair shop at confirm nga ng chief mechanic nila na atf nga yun leak.
Oil seal daw sa main drive yun leak. Baka raw matigas na kaya tumatagas yun atf ko. Iniwan ko yun kotse doon para ibaba daw yun main drive at macheck maigi yun leak & palitan yun oil seal. Anybody here experienced the same problem? Ano po yun solution na ginawa ?
Pic ng tagas na oil. Can you guys say na atf nga yun tagas base sa kulay at amoy ng oil?
thanks po.
