Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Hi mga Sir,
    Sorry po newbie lang ako pagdating sa mga car parts... recently nagpa change oil po ako sa Honda Shaw for my 95 Honda Civic Lx na 2nd hand and they found some oil leaks... so pina quote ko po kung mga how much po magagastos ko eto po sabi nila per item
    Class A (Needs Immediate Replacement/Safety Related)
    1. Oil Pan Gasket
    2. Crankshaft oil seal frt
    3. Camshaft oil seal fr
    4. Oil pump o-ring
    5. Crankshaft oil seal rr
    6. Nee to overhaul P.S Pump
    Sabi po sa akin from number 1-4 is 7k then yung number 5 is 5k and 6 is 5k as well.
    Ask ko lang sana if etong price na to is reasonable or ok lang sa iba ko to pagawa na mas less sa price? (Medyo tight sa budget)
    Thanks po sa lahat ng sasagot
    Sep 2004
    Something's wrong with the quotation. Over 17k?? (7k + 5k + 5k)
    Yung number 5 (crankshaft oil seal, right rear) is worth 5k?? Jeez, oil seal lang yun!
    To compare, I bought 2 timing belts, a set of oil seals and an oil pan gasket for my 97 Accord sa Honda Quezon Ave. Mga 6.6k lang ang damage.
    I suggest you get a quotation from a different casa. Taga masyado sa Shaw. Tapos paayos sa Speedyfix and look for Migs (malapit lang sila sa Honda Shaw). Search mo na lang dito for his exact address.
    Thanks po sa feedback. Nakita ko nga po yung SpeedyFix bale dun na rin po ba sa kanila yung parts if ever dun ko pagawa?
    Sep 2005
    sir...ung oil seals mo sa casa mo kunin kci sa experience ko sa labas ako kumuha eh tumulo agad. papalit mo na ring T-belt kung 2nd hand mo na nakuha para sure ka na hindi ka ibibitin sa biyahe.
    Aug 2006
    Quote Originally Posted by majorguile View Post
    Get a quotation from SpeedyFix and compare the parts and scope of work. Base from my observation, I see not just Honda cars but also BMW's being fixed there so maybe they know how to source original parts.
    I only go to SpeedyFix for change oil since my car is still new.
    super mahal naman,eh puro seals kang yan....sa labas mo na lang pagawa malaki pa matitipid mo, pwede mo pa kami malibre
    If you're near Honda Shaw, +1 to get an estimate from Speedyfix. They can get replacement parts with a little premium pricing lang nga (when I compare prices with auto supply stores after). Oks lang rin, at least less hassle to get the parts yourself.
    Else, another option, reco try Honda Q. Ave. - from experience, better orig parts pricing, and repair competence. It may not be perfect, but they showed better competence than Honda Shaw for us.
    Thanks po sa lahat ng nagreply... siguro magpapa-quote na rin ako sa speedyfix at honda QC. tawagan ko rin ulet si Honda Shaw baka mali lang sinabi sa akin... i mean, sinulat nya yung prices dun sa reciept nung nagbayad ako sa change oil kaya sure ako eto quotation nila pero baka mamaya kasi di talaga eto yung price sa CASA... alam nya kasi wala akong alam sa parts. Thanks po ulet mga bossing!!!
    Onga pala nasend ko sa report kanina yung message... sencia na hehe...
    Mga Sir,
    Nag pa quote ako sa speedyfix... eto po quotation nila
    1. Oil Pan Gasket 1900 labor 800
    2. Crankshaft oil seal frt 500
    3. Camshaft oil seal fr 500
    4. Oil pump o-ring 300 labor 1500 for the cam, crank and o-ring
    5. Crankshaft oil seal rr 1100 labor 2300
    6. Overhaul P.S Pump kit 1500, labor 1200, honda psf 700
    Obviously mas mababa sya kesa sa Honda Shaw... ang tanong ko lang po is yung labor po ba talaga is per part? Sencia na po talaga newbie lang talaga. Thanks!
    Aug 2006
    yung no. 5 ibaba transmission kaya mahal ang labor?
    Gannon ba ang singilan nila sa labor iba ang labor sa front at iba ang labor sa rear? eh iisang baklasan din naman tapos iba pa ang labor sa oil pan?
    I could understand na separate ang no. 6, but nos. 1-5 iisa lang dapat labor cost.
    Try to make TAWAD hehehe kausapin mo si Miggs
    Nov 2007
    Mga Sir,
    Yes, the labor is per part and it varies depending on the scope of work.
    May 2004
    sabay mo na di ntiming belt and water pump... para sure ka na hindi ka mapuputulan...
    ilan an ang mieage ng oto ?
    baka naman kailangan na i overhaul yan , sa laki ng trabaho at bumigay yung HEAD GASKET sayang lahat yung investment mo.
    majorguile, did Speedyfix get to see the car, or you just maybe called and asked how much for each of the repair items as diagnosed by Honda Shaw?
    If not, suggest let Speedyfix have a look at the oil leak so that they could give their analysis rin. Baka hindi lahat ng sinabi ng Honda Shaw, ay kailangan palitan.
    Nov 2003
    the estimate was given by email, we haven't seen the car yet.
    all i did was itemize the labor, if it's so important na isang labor lang yung work then just add up the individual labor charges and voila, one labor charge
    yes, number 5 involves removing the transmission.
    *Autobeat
    Di pa po pero balak ko na dalhin dun baka after next week.
    *bambino
    99K na po sir.
    *speedyfix
    Sir Migs, dalhin ko nalang dyan after holy week medyo busy kasi. Thanks pala sa prompt reply sa emails.
    Apr 2009
    Sorr Ot po ask ko lang if ganun kalaki magagastos mo mas maganda p b mgpalit ng engine? magkano mgagastos pag mag papalit ng engine ?. sorry newbie lng po and planning to buy a 2nd hand car din.. thanks
    Nov 2018
    Up for this thread mga mga bossing.
    My 2007 honda civic fd has an oil leak i went to a honda specialist mechanic somewhere in cavite di ko na bbanggitin yung name, pero dito ko rin sa tsikot.com sila nadiscover.
    Anyway, they told me na need ibaba/buksan yung makina para macheck and qouted 15-18k labor fee, hindi pa kasama yung parts and later on may add more cost depending sa makikitang issue.
    Any advice mga bossing?
    Currently on a tight budget, im thinking ipa-second opinion para may comparison.
    I read somewhere here and on the net baka may minimal parts lang na pwedeng palitan na hindi masyadong mahal ang gagastusin.
    Appreciate any advice TIA!
    pcv replaced?
    google pcv
    Quote Originally Posted by oleus101 View Post
    san daw galing leak? sa gilid gilid ba?
    para may idea ka san pcv valve
    2006-2015 Honda Civic PCV Valve Replacement DIY - YouTube
Oil Leak Quotation
