Results 1 to 8 of 8
    Oct 2011
    [SIZE=3]Mga sir ask ko lang po kung alam niyo kung anong sensor/part ng engine ng ford escape itong picture na ito. Nasunog kasi e hindi ko alam kung anong cause bakit nasunog. Thanks.
    [/SIZE]
    that must be your exhaust back pressure sensor ( EBP sensor) .get it diagnosed by a qualified tech ,
    chances are you may have a clogged up CAT CONVERTER . using an exhaust pressure gauge ,the tech
    should determine the condition of the CAT . *2500rpm it should read less than 2 psi .
    Oct 2011
    Thank you sir for the answer. Just 1 question, is it safe to travel? baka itirik ako or kung ano mangyari kasi
    kung malapitan lang naman or sa malapit na casa ok lang siguro ,pero observe pa rin since toasted yung part mo baka mag cause ng fire sa engine bay yung trouble .the best tow na lang sa trusted technician mo .
    Oct 2011
    for now wala pa wkasi akong makitang mechanic e, kung sa casa kasi baka mataga naman ako sa price may i know if you know a good mechanic for ford cars?
    one of the possible cause nyan pagkasunog ng dpfe sensor ay baka barado ng carbon yang egr tube (may butas na parang
    orifice yang loob ng tube sa pagitan ng 2 hose). linis lang katapat nyan, kung duda ka sa catalytic converter hanap ka na
    lang ng shop na may scanner na kayang bumasa ng oxygen sensors
    Oct 2011
    ok sir t2erns thanks hahanap pa rin ako ng mekaniko for now halos kasi yung iba hindi daw kabisado yung ford na sasakyan
    Jul 2003
    kaya ba makita sa OBD2 scanner ang trouble kung sakali?
    saan area malapit location mo?
Help! About Ford Escape 04
